View Poll Results: Has anyone partially blown a head gasket with ARP head studs?
yes
11.11%
no
88.89%
Voters: 9. You may not vote on this poll
Head gasket apperad to went bad with ARP head studs
Has anyone else partially blown a head gasket with ARP head studs? There is alot of oil all over engine parts below the manifold and underneath the motor and parts in close proximity. NO white smoke....Just trying to get a poll.
Oh o it looks like another one. Check my post. Did you install the stud into the block by hand? If you did that's the problem.
https://www.evolutionm.net/forums/sh...d.php?t=156413
Good Idea for a poll but I think that most people just end up with a small oil leak and not a blown headgasket. Maybe in time it could develop into that, is your headgasket blown?
Vtech8tr did the install and did a thorough job using a torque wrench. Not sure about retorqing them above that though. Did loosening and retightening the Head studs to a higher torque number help? Or should I just turn up the torque and continue to tightening the studs?
Originally Posted by TampaTurbo
I was going to check the compression but instead lifted the car and saw all the oil leading from the rear of the motor at the head gasket. All the head studs are torqued to 70ft lbs which was the figure a rep at ARP told me we should be using with ARP moly lube and 85 ft lbs using 30 wt motor oil.
Vtech8r is a good person and knows what he's doing. I would confirm with him as to whether he tighten the stud into the block by hand or by using a rachet. I believe that could be the problem. The installation in evom forum say to tighten by hand which I strongly don't agree to.
If I were you I would go back and loosen the nut and retighten the stud using a rachet and then tighen the nut to 85lb.
Good luck.
Good luck.
Good luck.
Something was done wrong in the install. ARP studs are a lot stronger than stock and the only reason you would have a problem is because of the studs not being fully seated, torqued etc.
I do recall doing the studs for you and you said to go by the ARPs instruciotns. I told you they needed to be torqued from 85-90 ft. lbs. You said that was too much, so i torqued them to 75ft. lbs if i recall correctly.
Mark yes only on a cold motor would you want to check them.
Originally Posted by VTECH8TR
Mark,
I wouldn't say that something was done wrong on the install but it could lead to problems if it was. If you have noticed several evo motors are seeing this issue with and without the HS install. I have seen it even on a fully built long block by a very good engine builder. I honestly think it has to do with the factory headgasket and the oil return passages but thats just my opinion.
