help me (trans problem)
Old Oct 21, 2005 | 05:17 AM
hornytoad's Avatar
Angry help me (trans problem)
okay maybe not a trans problem as much as a possible clutch problem...... so i was driving home on the 94 like always when i push my clutch in and it stickls to the floor and i was like f_ck*, and i could put it in gear and the clutch would not disengage, so i used my foot to pull the pedel back up, and the clutch worked fine again for like 6 more shifts the next time it went to the floor the clutch never engaged and it has not engaged since, i drove my car from lemon grove to el cajon and back to la mesa without a clutch, so here is the thing i have fixed a few trans. before, and it seems like a hydralic problem to me, is it my clutch, is there a place to add clutch fluid in these cars..... i really need some help.....
Old Oct 21, 2005 | 05:25 AM
C6C6CH3vo's Avatar
Good speed matching shifting. I wish I could give you advice I but I know very little in that area, I just had to comment on your ability to shift w/o the clutch. Did you match the synchro rate by reving it between shifts in neutral?
Sorry I didn't give any advice but it sounds like something is very wrong, but simple.
Old Oct 21, 2005 | 05:27 AM
hornytoad's Avatar
well i didn't always rev the engine in N, i just brought the car up to about 5,000rpms and then she shifted no problem from gear to gear, down shifting was a pain in the *** though.......
Old Oct 21, 2005 | 05:35 AM
Curt@MrLed's Avatar
Former Vendor
check the fluid.. .. easiest to say read owners manual... or the slave cylinder is going bad.. either on the firewall or the trans..
Wicked's Avatar
how do u stop?
definately sounds like a clutch problem to me, too bad i'm no expert.
Old Oct 21, 2005 | 05:45 AM
Boltz.'s Avatar
FCOTM Winner
He probably uses the brakes.
Old Oct 21, 2005 | 08:27 AM
hornytoad's Avatar
yeha i used the brakes, then i did a very bad thing and turned the car off, and put it in first then start the car, not good for the start and alot of other parts, but i made it home, where can i fill my clutch fluid at, i didn't see a a container for it in the engine compartment, anyone got a picture of it maybe?
Old Oct 21, 2005 | 02:55 PM
j8's Avatar
j8
It uses the brake fluid Reservoir for fluid. Top right hand side of the engine compartment.
Old Oct 21, 2005 | 03:10 PM
RiversideMitsu's Avatar
Sounds like low fluid for your master or slave cyclinder or they could have went bad. Check your fluid first.
