exedy vs rps cluth(twin plate)
Originally Posted by MattGold
Dude - where are you getting your information? Not flaming you, but you are completly wrong.
We have to assume here that the question is... "What's the difference between the RPS and Exedy Twin Carbon Clutchs?"
Comparing the Exedy Twin Metallic to the RPS Twin Carbon is not a direct comparison - ESPECIALLY when Exedy OFFERS a Twin Carbon Clutch.
Anyhow, the RPS uses *Steel Plates* with Carbon pads riveted on. The Exedy is a true Carbon Disc.
Sure RPS is rated higher - but show me a 10-second EVO running one (that actually keeps the clutch together). If you search the forums, all the REAL cars are running Exedy (either Carbon or Metallic) along side many of the fastest street cars.
AMS, Curt Brown, EvoDave, Dynoflash, Buschur, etc, etc, etc... can't all be wrong.
Anyhow, that's my .02 - PURE MR - don't take this as an attack - just clearing up misinformation.
Originally Posted by Z1 Performance
it matters if its a member car vs a shop car? Wow
RPS has a high entry point...Exedy is far more affordable alternative
Exedy NOW does rebuilds for their multiplate clutches! Not sure of the cost though.
Originally Posted by Jack @ EvoStore
Do you happen to have the contact information for the rebuild department?
I see a ad in the mag saying RPS clutch is the last clutch you will ever need. What exatly does that mean... it will never break, and if it does you just need to rebuild it? Arent all clutches rebuildable?
Originally Posted by smokedmustang
MattGold has that info I believe, he used to work there! Call Daiken Clutch in Michigan and ask them. There is more info on this subject on one of my posts! you can check on my threads. I am not that computer bright, so I dont know how to post it here.
That, to me, is another thing that needs to be taken into consideration when deciding between multi-plate clutches like the various Exedy, the RPS, and the Tiltons. Being rebuildable doesn't do you any good if you can't get it to the manufacturer to be inspected and rebuilt.
It may be a pertinent question. Actually, the more pertinent question may be, "How many of those shop cars are running Exedy because they got them for free?"
Originally Posted by PURE MR
The rps one is a much stronger clutch, with torque ratings of about 800 lb/ft. Very extreme clutch. It is basically a bulletproof clutch, but again you better be making some serious power in order to run that clutch.
Everyone go by that clutch
I'll be waiting....
Jon@TRE
I've heard of a couple of people having issues with carbon-carbon clutches slipping if they are not hot (exedy specifically, not saying that other brands don't as well). Is this true or are these the result of a poor install, bleeding of the clutch, or something along those lines.
What I'm getting out of it is the main advantage of a carbon-carbon setup is it can be slipped more than organics, grip more as it get hotter and not burn up. How are they for everyday driveability? I don't beat my clutch that much but, when I have to replace it I only want to do it once and be done with it for a good long time.
the purpose of carbon in a clutch is for slipping! You can slip a carbon clutch to your hearts content and not overheat it like an organic, ceramic or other type material. Ever heard of carbon brake rotors. Just an example of the benefits of carbon. The reason it costs more, is it's harder to work with and more expensive to manufacture. Not taking anything away from other clutch manufacture's, but RPS is a top notch company and they stand behind their product with good customer service.
I'm by no means a drag strip warrior or even a good driver for that matter, but wouldn't a 7000 rpm launch while slipping the hell out of the clutch be more "friendly" to downstream driveline components than a 6000 rpm clutch dump, because your ceramic clutch isn't designed to slip that much before it blows up?
I guess it's a matter of what you're going to use the car for. I do know that RPS will replace all carbon wear surfaces for free once you pony up the initial investment for one of there setups. That's what they mean by the "last clutch you'll ever buy".
