rpms seem to hang...
Old Oct 28, 2005 | 12:13 PM
Blackie9900's Avatar
is there anything ican do to my car that will get rid of this? like when i go to shift from 1st to second i let off gass and poull in clutch and the rpms clim up, and seem to hang up there for a sec or 2, right now my car has got dynoflash, 3"tbe no cat, aem intake, forge bov, helix ic pipes, hallman mbc, walbro pump, could it be that my bov is recirculated? it never used to do it this bad...
Old Oct 28, 2005 | 12:16 PM
slow_evo's Avatar
Is your clutch slipping?
Old Oct 28, 2005 | 12:21 PM
mac_05evo's Avatar
my car does this too.. dunno why..
Old Oct 28, 2005 | 12:25 PM
Ev0ikon's Avatar
The 05 should do that , but not the 03.
Old Oct 28, 2005 | 12:35 PM
dan628's Avatar
my 05 does NOT do that, sounds like something is wrong.. better get it look at ASAP!
Old Oct 28, 2005 | 12:37 PM
bigjhoney's Avatar
Make sure your foots not on the gas. Try shifiting again but make sure your foot is all the way off, see if its still around. I catch myself doing it once in a while.
Old Oct 28, 2005 | 12:38 PM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...7&page=1&pp=15
Old Oct 28, 2005 | 01:00 PM
dubbleugly01's Avatar
two people on this thread complained about rpms hangin...... at least one common denominator, the aem intake. Put the stock box back in and see if the problem goes away.
Old Oct 28, 2005 | 01:06 PM
4TUN8's Avatar
happened with my typhoon intake as well.
Old Oct 28, 2005 | 01:14 PM
godog6's Avatar
It's called a flat shift...
Well I'm no expert, my car does that also, 03, but my mechanic programmed my autronics to do exactly that.
When done correctly, it allows you to be shifiting into power vs having the engine lag and catch up. It is quite sweet when you hit it right. This should only happen when you're hitting it hard, maybe in the 4500 - 6000 range.
Hope it helps...
Old Oct 28, 2005 | 01:28 PM
dan628's Avatar
when are people going to learn. Intakes are responsible for many problems people keep having on here, yet they keep using them.... I guess they deserve what they get....
Old Oct 28, 2005 | 05:59 PM
my car did this when it was stock.... it was not noticable caus of the exhaust.. but it still did it... now with the exhaust.. tis just more annoying.. and my clutch pedal has a little bit of play b4 it gets hard
Old Oct 28, 2005 | 06:27 PM
Sam - PURE Tuning's Avatar
Former Vendor
I thought I read somwhere that 05 & 06 evos had hanging rpms...not sure though.
Old Oct 28, 2005 | 06:32 PM
eve-slow's Avatar
My EVO did that for a long time, then it eventually went away. Although, it did it in most gears. From what I remember, there was no definitive solution at the time.
I'm guessing it was clutch related.
Old Oct 28, 2005 | 06:35 PM
blackevo110's Avatar
clutch
