rpms seem to hang...
Old Oct 28, 2005 | 06:43 PM
Evo_SpeedKing's Avatar
many claim it to be the clutch and on an 03 it might be, but there is a growing list for 05 owners. at our last meet 2 members complained about this problem. one was fully stock and had less than a few thousand miles, could be just an ecu problem.
Old Oct 28, 2005 | 06:48 PM
MalibuJack's Avatar
If you have a stock DV, make sure its not on backwards.. If you have an adjustable DV, try to use a lighter spring pressure.. It should help most of these symptoms.. Assuming its not the clutch slipping slightly..
But I know what your describing, at part throttle but high boost, you shift gears and the RPM Rises between gears.. I have been able to isolate it to high spring pressure in my DV.. If you have a forge valve, it probably has the yellow spring in it.. run a lighter spring in it and it should help.
Old Oct 28, 2005 | 06:49 PM
MalibuJack's Avatar
Oh and I have seen TWO occasions where the stock DV was installed backward from the factory..
Old Oct 28, 2005 | 07:53 PM
Speedlimit's Avatar
Admin Emeritus
If your throttle body valve is not sticking when in gear (take your foot off the gas and if rpm drops immedietly) then it might be compressor surge caused by delayed relief and or insufficient flow rate of your bypass valve. i.e. tight spring pressure as Jack suggested.
Moving to tech forum.
Speedlimit...
Old Oct 28, 2005 | 07:56 PM
BBYBruno's Avatar
Your not shifting right. Your letting off the clutch too slow and still on the gas.
How many off these threads are we going to have!
Why do people think it's mechanical?! It's your driving.
bcruz463
Oct 28, 2015 11:41 AM
dadsgts
17
Apr 27, 2011 04:30 PM
highpockets
Jul 10, 2010 11:14 PM
damstr
Jun 26, 2008 11:36 AM
jesterEVO
Dec 11, 2005 08:40 PM
