Upside down bov
Old Dec 11, 2005 | 06:49 PM
jesterEVO's Avatar
Upside down bov
My aps bov has to hang upside down because the logic perforamce upper ic pipe has the hole at the bottom facing the ground. So the top of my bov is facing to the ground. IS that bad? I do notice a flutter when i hit the gas and stop shift before higher rpms and when i dont build enough pressure it flutters which i think is normal for that. WOT it sounds nice.
Old Dec 11, 2005 | 07:59 PM
Atlas's Avatar
yes. your car will boost backwards. oh noes!!1!
it shouldn't be a problem unless things are not mounted correctly.
Old Dec 11, 2005 | 08:10 PM
en1gma19's Avatar
the orientation of the bov to the ground has no effect on it's functionality. If it flutters it's because the spring is too tight (if it's adjustable) or vaccuum line isn't properly routed.
Old Dec 11, 2005 | 08:40 PM
jesterEVO's Avatar
bottom of bov routed to ic pipe and side of box to the intake...vacuum hose connected like it should...aps does have adjustable spring does it?
lpy2009
Feb 26, 2012 12:09 PM
06GraphiteEvoIX
32
Mar 11, 2010 08:45 PM
Talon_66
Apr 17, 2008 09:05 PM
chizcwish74
26
Jun 19, 2005 09:02 AM
upjess
Feb 1, 2004 08:03 PM
