Fluttering stock BOV
Old Jan 31, 2004 | 09:21 PM
upjess's Avatar
I was just wondering why? When I let off the gas at light to moderate throttle my bov flutters. It's pretty annoying. I checked the vac line going from the BOV to the intake doesnt seem to be crimped. Is the flutter normal? Any suggestions would be appreciated.
Old Jan 31, 2004 | 09:28 PM
blonde's Avatar
did you do anything to the engine that required taking out the bov? if you did than you might have installed it backwareds like so many people do....
Old Jan 31, 2004 | 09:48 PM
DRWN KIX's Avatar
I recently had warrantee work done at a Mitsubishi dealer. When I got the car back it sounded different and lurched in unloading conditions. It was spiking 1.6 bar instead of the normal 1.44 as well. BOV was installed backwards.
Old Jan 31, 2004 | 11:21 PM
upjess's Avatar
Yeah! I put in a new inlete pipe. The flat circular part of the bov should be facing toward the radiator and turbo side. Right? I'm still mantianing 19-20psi of boost. I don't know! I'll be getting a new bov anyway since I'm going to be putting in a mbc. Hopefully that will solve the problem, but in my research some of the guy's been having the same problem with these after market bov's also. what do you think?
Old Feb 1, 2004 | 06:44 AM
Grod101's Avatar
sometimes it is normal if it flutters a little when you let off the gas and the turbo is starting to spool....
Old Feb 1, 2004 | 08:03 PM
upjess's Avatar
I was thinking it would be. Thanks for the reply.
lpy2009
Feb 26, 2012 12:09 PM
jd888jd
17
May 8, 2009 06:47 AM
bben411
Apr 24, 2008 05:54 AM
joon82
12
Jul 8, 2007 05:52 AM
bishiboy
60
Jun 25, 2004 10:53 AM
