Help With BOV flutter!
Old Mar 21, 2008 | 02:13 AM
bben411's Avatar
I just recently installed a perrin MBC and im also running a greddy RS BOV. Im getting some flutter around 50% throttle and it only happens only after 3500rpms+. What are my options to fix this?
Old Mar 21, 2008 | 02:15 AM
bluebanana23's Avatar
check your diagphram
Old Mar 21, 2008 | 02:30 AM
bben411's Avatar
What Bov would eliminate this problem?
Old Mar 21, 2008 | 02:50 AM
Cali2MDevo8's Avatar
Registered User
Purchase a evo 9 metal BOV or JDM evo 8 metal BOV. Much less flutter. Flutter is going to happen with any strong springed DV
Old Mar 21, 2008 | 03:09 AM
kmcconn9's Avatar
there is a fix for the greddy rs valve to eliminate this problem. Look around and you will find it.
Or, the simpler fix would be to get a JDM evo 9 valve. When in doubt go OEM with a bov as at your boost level (stock turbo) its going to be the best choice for you.
Although you could looking into the synapse engineering bov. I will have a complete review of this bov in a couple days.
Old Apr 23, 2008 | 09:48 AM
mrfred's Avatar
Did you get a chance to post a review?
Old Apr 23, 2008 | 05:37 PM
evo150's Avatar
have you done the single spring mod to your greddy rs bov yet? http://evomoto.com/tech_info.php?tPa...3451166315b271
Old Apr 23, 2008 | 07:58 PM
Dipz's Avatar
That's showing a Type-S, I'm not so sure that they're the same thing.
Old Apr 24, 2008 | 03:13 AM
PWevo's Avatar
The single spring mod still applies for the RS, I've previously done it and it worked for a while. That was until the diagphram crapped out on me and developed a few small cuts causing the fluttering to come back. Check your diagphram for cuts. Overall I'd go with the IX bov.
Old Apr 24, 2008 | 05:54 AM
mercsan's Avatar
BOV and EVO dont belong in the same sentence. BUT if you really want one. Buy a dual port, or else you're gonna have problems. Best bet is to go with the metal MR BPV!!!
kanovic
Dec 15, 2012 12:30 PM
lpy2009
Feb 26, 2012 12:09 PM
Box Rocket
12
Sep 5, 2008 01:04 PM
mobounce
Oct 12, 2004 09:39 PM
bishiboy
60
Jun 25, 2004 10:53 AM
