helix 3" dp help
Old Nov 1, 2005 | 04:01 PM
sandm's Avatar
helix 3" dp help
I have a helix 3" dp and a helix hf cat on my stock turbo'ed 03. my downpipe rattles against the 2 lower braces. I have heard that the cusco unit will eliminate this...looking for someone that has had this same issue or knows if the cusco unit hangs lower than the stock 2 crossbars..
thanks for the help
Old Nov 1, 2005 | 04:05 PM
kimletrim's Avatar
Registered User
Just get spacers (thick washers) for the screws that attach lower braces to the car. Much cheaper and works like a charm.
Old Nov 1, 2005 | 05:07 PM
dubbleugly01's Avatar
I thought my dp was hitting the lower tie bars also, but it turns out it was hitting the heat shield around the factory cat. Not questioning your judgement, just offering a suggestion, can you see any rub marks to verify it really is the lower tie bars that are rubbing?
Old Nov 1, 2005 | 06:12 PM
BigAeVo's Avatar
mines rattleing against something not sure what, it didnt rattle when i had a greddy TI catback, it rattles now that i have a hks exhaust
Old Nov 2, 2005 | 04:18 PM
sandm's Avatar
can't be the cat...don't have one(helix hf cat if you want to call it one). no heat shield. it is hitting the tie bars.
my original question still stands. does the cusco bar hang lower and allow for more clearance for downpipes?
savageevo
Jun 27, 2007 06:54 PM
4-BNGR
13
Mar 2, 2007 10:59 PM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
44
Feb 28, 2007 02:08 PM
BoostWhore
10
Jun 27, 2006 07:36 AM
ev08buoy
Sep 14, 2005 06:23 AM
