Need Fidanza cam gear instructions NOW! HELP!
Old Nov 3, 2005 | 05:32 PM
smokedmustang's Avatar
Unhappy Need Fidanza cam gear instructions NOW! HELP!
I have been told my vibrations are due to the cams being off or RETARDED 62-92 degrees! WTF??!!! I normally dont cuss, but W T F !!! does anyone have the installation instructions? please PM them to me, or show me where I can find out the install instructions! I am standing by, as I know you will help me out! Thanks in advance
Old Nov 3, 2005 | 05:38 PM
Soon2BEVO's Avatar
who told you that?
Old Nov 3, 2005 | 05:44 PM
the new master tech. who pulled the cam cover off. But he is not sure of the way the gears line up. I doubt its off that much, I had it dynoed at dyno4mance, ran 135 MPH at putnampark raceway (roadcourse) and didnt have a problem. except the pop-pop of the methanol at high RPM.
Old Nov 3, 2005 | 05:49 PM
evo 8 ya's Avatar
man you need a new master tech. your valves would be hitting the tops of the pistons if they were that much off
Old Nov 3, 2005 | 05:54 PM
I agree with you evo8ya, he just said they are really off! but I haven't had trouble driving it, except at high RPM with what I assume is the Meth not tuned. It idles fine, and only vibrates my butt at 4K RPM and higher. I dont get it, I am not a mechanic, but there is no way it would run. he said the computer can compensate for 90 degrees. He is a Master tech Evo mechanic, and has run 4G63's all his life in 1/4 mile increments. He didn't install the cams. would the balance shaft being upside down cause him to see the cam gears off?
Old Nov 3, 2005 | 05:58 PM
Soon2BEVO's Avatar
Go to a reputable performance shop
Old Nov 3, 2005 | 06:30 PM
He will be pulling them out tonight, and re-doing them. will post results tomorrow Thanks again. My un-educated guess, the balance shafts are off, and the cams are off a FEW degrees! Thanks again, Kevin
Old Nov 3, 2005 | 06:39 PM
USP45's Avatar
If these are the vishnu cam gears you really need to call them as their cam gears to not index the way all others do....
Old Nov 3, 2005 | 07:26 PM
dubbleugly01's Avatar
you would have all sorts of driveability issues if a cam was off that much. If it would run at all is the question. Your master mechanic obviously is looking for a reason "other" than the Mitsu parts. And I doubt he knows anything about adjustable cam gears. It's the "unknown" to him, and he's going to jump all over it. Balance shaft is the answer.
not to mention valve/piston contact!
Old Nov 4, 2005 | 02:01 AM
Thanks dubble, I agree, and he told me he is unfamiliar with these gears. I hope when I get there today, he solved the problem. Thanks for your input, I appreciate it.
Old Nov 4, 2005 | 05:56 AM
evo 8 ya's Avatar
no it would just cause a vibration.
tpm17
Jun 1, 2019 07:09 PM
Evojj25
Jul 13, 2009 02:38 PM
Profoxcg
Jun 11, 2007 08:23 AM
cyberninja
Jan 29, 2005 02:58 PM
petersa9
10
Jan 26, 2004 06:51 AM
