Blew 05 stock turbo
Old Nov 4, 2005 | 05:57 PM
j8's Avatar
j8
Well, Anthony has raced the hell out of that thing by hitting 12.1s with hardly any mods then going 11.8s after cams. What I don't understand is why in the hell they replaced it with no questions asked when he has cams, FMIC, mbc, safc, blah blah blah. Maybe he removed some of that stuff before going in, but damn, they should have been able to tell he's raced the hell out of it. Hopefully, if/when this ever happens to me, I get the same treatment, especially since I don't even have cams or an FMIC...
The dealship here has covered quite a few things for me with no questions asked. I have a standalone ECU also. It depends on the service department.
Old Nov 4, 2005 | 06:14 PM
BMan's Avatar
Originally Posted by ibanez_926
sounds like what an 9.8 hotside turbo does
That's the first thing I thought of.
Old Nov 4, 2005 | 06:19 PM
Spec'd's Avatar
Makes sense.
Also makes sense... Can't help but wonder.
Old Nov 5, 2005 | 12:28 AM
SeanJhn9's Avatar
my water pump went out on me for some odd reason, took it in to the same dealership with aem installed and wideband right where the stock clock is and they replaced it no ?'s asked as well
Old Nov 5, 2005 | 06:58 AM
EVO3675's Avatar
Check the stock engravings on your turbo it is TDO5HR16G 10.5 on the newer and it is 9.8 on the older the markings are on the side of the compressor housing
Old Nov 5, 2005 | 07:02 AM
wizzo 8's Avatar
Im curious what the numbers are also. Let us know. My 05 peaks at 21 and drops to 19 also.
Old Nov 5, 2005 | 08:22 AM
sleet's Avatar
Very weird, maybe they put an 03 turbo in there.
Old Nov 5, 2005 | 08:41 AM
KazzEvo8's Avatar
Check for boost leaks.
Old Nov 6, 2005 | 04:20 PM
whiteevo311's Avatar
Im guessing its a boost leak. Ive been gone hunting all weekend but after driving it again I noticed a few more things. It tries to boost higher but just falls off. Its also idling higher. Like 900-1100rpms and my vacuum is only at like -10psi when Im sitting there. Its usually at -13ish. Whats everyone elses vacuum at idle?
Old Nov 6, 2005 | 07:31 PM
wizzo 8's Avatar
Sounds like you have a vacuum/boost leak. At idle its about 14-15 for vacuum.
