avcr help!!!!!
Old Nov 4, 2005 | 04:00 PM
Jessie's Avatar
avcr help!!!!!
ok i have it completey installed and it was working great but then a friend of mine was ****ing around and accidently pulled the hose off the wastegate and i didnt notice until i boosted over 25 psi. so now everything is hooked back up and im only bossting to 11 or 12 and it wont go up....any ideas
Old Nov 4, 2005 | 04:31 PM
Gruppe-S's Avatar
Um...I would check all the settings in your AVCR because it has self learning mode. It might adjusted the duty cycle if it sense something wrong. Other than that, I would check all hoses again and check for boost leak.
Thanks,
Tom
Old Nov 4, 2005 | 04:37 PM
Jessie's Avatar
we just re routed the hoses to make sure theres not a boost leak. Is there any way to reset the avcr?? I think maybe i can start from the beginning again and getting all of the settings correct without having to worry about anyone pulling off my hoses
Old Nov 4, 2005 | 04:40 PM
Gruppe-S's Avatar
You can initialize the control unit under etc.
Tom
Old Nov 27, 2005 | 09:32 AM
Kayaalp's Avatar
So, you overboosted and now the car won't boost more than 11-12 pounds? Sounds like you blew out the diaphragm of your diverter valve. The stock DV is notoriously weak.
Emre
