The DiaQueen gear oil question
Old Nov 4, 2005 | 04:17 PM
LT1runner's Avatar
The DiaQueen gear oil question. PLEASE HELP!!
I bought the $85 "MR" can gear oil, not seeing the $50 can. Can I use the 85 dollar "MR" fluid in the transfer case? Or should I buy the $50 GL5 LSD gear oil? This to change the transfer case fluid.
Old Nov 4, 2005 | 04:23 PM
Spec'd's Avatar
In the MRs you are suppossed to only use the "MR" fluid in the 6 speed gearbox.
The other GL5 LSD Diaqueen gearoil can be used on the front and rear differentials for all Evos ... MR, GSR and RS.
Old Nov 4, 2005 | 04:24 PM
edwin's Avatar
Transmission fluid and transfer case use different oil.
Old Nov 4, 2005 | 04:27 PM
edwin's Avatar
BG Syncro Shift from anywhere( for any EVO )
GL5 LSD gear oil from Mitsubishi( ask Mitsubishi )
Old Nov 4, 2005 | 04:36 PM
Spec'd's Avatar
It tells you what to use in the owners manual.
Old Nov 4, 2005 | 04:51 PM
eling99's Avatar
Old Nov 4, 2005 | 05:38 PM
Derek888's Avatar
I have both the english and chinese Evo manual from Mitsubishi and the English version tells me to use GL-4 and Gl-5. But the Chinese one says to use gl-4 on both transaxle and transfer case
Old Nov 4, 2005 | 06:15 PM
Spec'd's Avatar
That's a good question.
I can't image the Chinese spec being different for drivetrain fluids.
( but I could be wrong )
However it's pretty typical to use API GL-4 in the Evo 5 Speed transmissions.
i.e. Redline , Syncromesh, BG, etc.
In the MR 6 speed transmissions, I would use nothing but the Mitsubishi
Diaqueen Super Multi Gear Oil. ( If it was my car. )
I see no mention of viscosity for the MR 6 speeds.
Someone please advise if they know for certain.
The front transfer case and rear differentials use API GL-5.
Mitsubishi recommends thier Diaqueen LSD Oil or equivelent.
( This is what I would also use in my own car )
Can also use Mobil 1 GL-5 gear oil.
This applies to all Evos ... RS, GRS and MR.
Old Nov 4, 2005 | 06:20 PM
Derek888's Avatar
All LSD oil should work correct? Because the only thing they have for the LSD oil is from Cusco.
Old Nov 4, 2005 | 06:23 PM
Spec'd's Avatar
Sorry, Not sure what your question is.
Are you saying you can only get oil from Cusco ?
Old Nov 4, 2005 | 06:49 PM
edwin's Avatar
ni hao mah?
Old Nov 4, 2005 | 07:36 PM
Derek888's Avatar
The only oil they have here is Redline Gear oil which is GL-5. All the gear oils they sell here are GL-5. Do you think its ok to use GL-5 for the transaxle and transfer ? For the LSD oil they sell Cusco LSD oil that is GL-5. These are the only two bottles I was thinking to put in the car.
Old Nov 4, 2005 | 07:37 PM
Derek888's Avatar
Originally Posted by edwin
ni hao mah?
i dont know ping ying but... wo hen hao shei shei
Old Nov 4, 2005 | 07:41 PM
Spec'd's Avatar
In the front transaxle or transmission, I would really try to get GL-4.
In the front transfercase and rear differential the GL-5 is fine.
Old Nov 4, 2005 | 07:47 PM
Derek888's Avatar
ok thanks
