EVO understeer
Old Mar 17, 2003 | 03:23 PM
zyounker's Avatar
EVO understeer
Anyone have a cheap way to get the evo to not understeer so bad? It really pushes on tight corners.
I am looking for hopfully some EVO7 drivers or some people already out racing to respond.
Thanks,
-Zach
Old Mar 17, 2003 | 03:33 PM
zyounker's Avatar
Or more so then cheap, is easy.. I would like to have the car preped for next weekend.
Or am i gonna have to order stuff from japan?
Old Mar 17, 2003 | 03:41 PM
wtz's Avatar
wtz
Hi,
Get a good alignment. -2 degrees front -1 degree rear. 1 or 2 mm total toe out front will help turn-in. 0 toe rear. If you are running a DOT race tire, a little less hot pressure up front will give you more bite. Next step, front LSD.
Cheers,
Old Mar 17, 2003 | 03:45 PM
zyounker's Avatar
Thanks WTZ.
How bad does that effect tire wear? should i switch it back for street driving or are the effects minimal.. (I don't care about a few less miles)..
Thanks,
-Zach
Old Mar 17, 2003 | 03:47 PM
evo_dan's Avatar
I have a both cheap and easy solution for understeer. Lift off the throttle once in a while. j/k Sorry, I couldn't resist.
Old Mar 17, 2003 | 03:50 PM
zyounker's Avatar
Old Mar 17, 2003 | 03:58 PM
wtz's Avatar
wtz
It will wear out the inside edges of your front tires with normal street driving. Get together with your alignment shop and develop 2 settings for street and race. If they are nice, they will show you how to go from one to the other. It's not difficult but may not be perfectly precise.
Cheers,
Old Mar 17, 2003 | 04:01 PM
zyounker's Avatar
Thanks WTZ
-Zach
Old Mar 17, 2003 | 04:17 PM
Secret Chimp's Avatar
Could it be a driving style issue? Are you used to driving fwd or rwd?
SC~
Old Mar 17, 2003 | 04:18 PM
zyounker's Avatar
SC~
AWD... I just went from a WRX...
Thanks,
-Zach
Old Mar 17, 2003 | 04:30 PM
Maxi's Avatar
First chech the tyre pressures, for the evo vi they are 2.2bars front and 1.9bars rear.
Then check your geometry settings. You should be able to put 2.0 negative camber on the front even with standard shocks.
For better results, you will have to fit a front cusco or ralliart lsd, better tyres like yokohama a032r, and better suspensions.
Old Mar 17, 2003 | 08:48 PM
3171's Avatar
check your tyre pressure. are you running semi-slicks or road tyres?
Old Mar 18, 2003 | 06:59 AM
91TB78's Avatar
Can't you also go with a larger rear sway bar..say by 1mm in the rear to decrease understeer?
Old Mar 18, 2003 | 08:52 AM
zyounker's Avatar
The car is still 100% stock..
The car is completely controlable.. But i just don't like so much understeer.
I will be trying the alignment probably this weekend.. Assuming i can find a place that will let me mark the settings..
I had one idea.. I could mark the settings now, take it to a shop have them change it to -2 in front & -1 in the rear. Then i could mark that.. and i would have my 2 marks..
-Zach
