sc61 vs. gt35r
Old Nov 7, 2005 | 08:11 PM
evoblack9's Avatar
sc61 vs. gt35r
I am running a precision sc61 right now and i am happy with it, but i am considering switching to a gt35r...Can anyone give some advise on the switch...Will it be worth it? Will I even make more power??? Thanks!!
Old Nov 7, 2005 | 08:21 PM
04 rs's Avatar
precision is supposed to make the sc61 in ball bearing in the near furture so maybe you should hold out for that. As far as i can tell it will be cheaper then the gt35r also
Old Nov 7, 2005 | 08:39 PM
mchuang's Avatar
they actually sell ball bearing upgrade kit for t3/t4 turbos..
Old Nov 7, 2005 | 10:10 PM
DSMotorsport's Avatar
you should see very little performance increase in power, as the comp wheel is the same, comp housing same, only the turbine wheel would be different.
The BB center should spool slightly faster, but might cause compressor surge in high gears.
Old Nov 8, 2005 | 06:32 AM
evoblack9's Avatar
thanks for the help....maybe ill just sit tight for a little bit
Old Nov 8, 2005 | 08:20 AM
Soon 2 B EVIL's Avatar
there are about the same turbo just the SC61 in NON-BB. as of Preicision doing that Center BB it hasnt gotten to the SC61 yet.
Old Nov 8, 2005 | 08:23 AM
Torre from Va.'s Avatar
A GT35R is basically a dual ball bearing sc61 from my understanding.
Old Nov 8, 2005 | 08:47 AM
xepyt's Avatar
I thought that BB turbos don't necessarily equate to faster spool, but instead more consistent lasting spool between shifts.
Old Nov 8, 2005 | 09:30 AM
The correct way to look at it:
The SC61 is just a normal standard T3T4E-Stage 5 turbine wheel turbo, using the compressor wheel from a GT35. To4E compressor housing machined to fir the 35R comp wheel. Standard old style garret bearing housing, old style T3 turbine wheel, Standard T3 turbine housing. The only new style part is the 35r comp wheel.
Old Nov 8, 2005 | 10:25 AM
jj_008's Avatar
This is correct, but the turbine wheel is alot bigger on a SC61 then the GT35R turbine wheel. The SC61 will produce more power (due to its bigger turbine wheel) at the expense of spool up. The SC61 is going to be painfully laggy w/o a ball bearing conversion.
Old Nov 8, 2005 | 10:29 AM
mchuang's Avatar
I am pretty sure that it is available..garrett makes precision turbos and the ball bearing option is available for t3/t4's check this link http://honda-tech.com/zerothread?id=1388103
Old Nov 8, 2005 | 11:03 AM
04 rs's Avatar
precision make theres own turbos using garret parts, garret does not make there turbos. The sc61 will be available in ball bearing in the near future
JakeTheVIII
13
Jul 7, 2009 05:26 AM
evoblack9
AEM EMS
Oct 15, 2005 08:01 PM
slowTsi
Automotosports - Illinois
Jun 13, 2005 09:13 AM
RnR Racing
138
Mar 25, 2005 01:21 AM
Evoisdream
Mar 6, 2005 02:48 PM
