270 whp looking to be at about 290 whp
Old Nov 8, 2005 | 06:24 PM
MidEvo's Avatar
hey guys i have a white evo with hks 264 cams, hks downpipe, hks carbon ti exhaust, intake filter, and xflash from vishnu and put down 270 whp. the car is nice now but im looking for about 20 more reliable whp and i will be done with the power adders. what do you suggest is the best way to do this? i want to keep this car as reliable and daily drivable as possible. im thinking 10.5 hotside, cat delete and maybe exhaust manifold? what do you guys suggest?
Old Nov 8, 2005 | 06:37 PM
HiRevnVIII's Avatar
the major restriction in your system is still there, the cat. removing that will free up some ponies. I would say that putting a hotside will give a little more power but will give you even more with a cat delete.
Old Nov 8, 2005 | 06:38 PM
USAF_STi's Avatar
the 10.5 would be a great start. lower intercooler pipe and a a o2 housing. the cat deleat would pick up a couple of HP
Old Nov 8, 2005 | 08:01 PM
forum04pl's Avatar
definatly get rid of the cat and maybe try a mbc. if you dont have a fuel pump i would reccomend one just to be on the safe side too.
Old Nov 8, 2005 | 08:12 PM
Gruppe-S's Avatar
I noticed you are from the Bay. which dyno did you hit 270 at? I hit 290 on my dyno with hks 272, 70dp, helix high flow cat, hks exhaust, helix 02 housing, and a hks panel filter. My car is an 05 tuned with Ecutek.
Give me a call if you have any questions.
Tom
Old Nov 8, 2005 | 08:15 PM
Doogie Howser's Avatar
He most probably got his numbers on a dyno dynamics dyno.
Old Nov 8, 2005 | 08:54 PM
Mikey Rudamann's Avatar
A cat-delete is probably the cheapest. I purchased the Helix Cat-Delete for ~$100.00. Worked perfectly and it helped a lot.
-Mike
Old Nov 9, 2005 | 06:28 AM
C6C6CH3vo's Avatar
The catyletic converter, especially at this point, is holding you waaaay back. GET RID OF. With all your mods - it's lock up 15HP consevativly
10.5 for another strong 5 - 10
I don't think the ex manifold would be worth the trouble at this point.
Old Nov 9, 2005 | 06:39 AM
hotrod2448's Avatar
Why just 20? Why not make it 30 and hit a nice even 300whp?
Get a high flow cat or a cat delete, lower IC piping, maybe an 10.5 hotside and a custum tune and you should be there or over.
Old Nov 9, 2005 | 06:51 AM
TxEvo8's Avatar
+1 but you should get another reflash after the FP and MBC (+1-2 psi), I think you'll be over 300 with this setup
Old Nov 9, 2005 | 04:02 PM
MidEvo's Avatar
cat delete, upgraded o2 housing, and 10.5 hotside with another reflash and i should be good in the 290-300 range? i hit 270 on shivs dyno. oh also i have a walbro 255 fuel pump
Old Nov 9, 2005 | 04:07 PM
evolgrl's Avatar
Cat delete and a maifold.
s2k zyke
34
Jun 19, 2013 05:19 PM
jlog1506
Dec 8, 2012 01:37 PM
Bpower
38
Sep 26, 2012 07:58 AM
honda-guy
58
Mar 21, 2012 03:50 AM
94AWDcoupe
May 6, 2008 04:02 PM
