AEM wideband hookup
Old Nov 8, 2005 | 10:00 PM
mikiblueeyes's Avatar
AEM wideband hookup
Hey Guys. Please advice on HOW to hook up AEM Wideband sensor to the AEM EMS (model 30-1313) NOTE not U.
I just purchased it and cannot find a way to where hook up the wideband wires. It just says to install the sensor inplace of O2sensor on the dump pipe.
Please advice.
Old Nov 8, 2005 | 10:16 PM
bolsen's Avatar
ADVANCED ENGINE MANAGEMENT INC.
2205 126th Street Unit A, Hawthorne, CA. 90250
Phone: (310) 484-2322 Fax: (310) 484-0152
http://www.aempower.com
Instruction Part Number: 10-2300 Rev 4
 2003 Advanced Engine Management, Inc.
Page 1
Installation Instructions for:
30-2300 Dual Channel &
WARNING:
30-2301 Single Channel
O2 Sensor Controller
This installation is not for the electrically or mechanically
challenged! Use th th EXTREME
is sensor wi
uncomfortable with anything about this, please refer the installation to an AEM trained tuning shop or call 800-423-0046 for technical assistance. You should also visit the AEM Performance Electronics Forum at http://www.aempower.com NOTE: AEM holds no responsibility for any engine damage thaesults from the misuse of this product!
r
caution! If you are
t
and should
never be used on public highways.
This product is legal in California for racing vehicles only
into vehicles already fit ggers. It furnishes the
user with real time, accu m consists of the AEM
UEGO controller with wiring harness and one or two Bosch wide range sensors with weld in
sensor bungs. The controller is available as both a single or dual channel system with one UEGO
sensor per channel.
Each O2 channel features two different analog outputs, a 0-5 volt signal and a 0-1 volt signal.
The 0-1 volt is a “Lean to Rich” calibration specifically designed to simulate the output range of
a narrow band type sensor. This can be fed into a stock ECU to keep from generating a failure
code in the ECU. It can also be used on older aftermarket ECU’s that expect a 0-1 volt narrow
band type signal.
The Advanced Engine Management (AEM) Wideband O2 Sensor is designed for integration ted with aftermarket ECU’s or OBD port data lorate and repeatable air/fuel ratio values. The syste AEM’s O2 Sensor Kit (single channel shown)
The UEGO controller’s ultra-compact size can be mounted in the engine compartment or under
the dashboard. It is very light and can easily be mounted with the supplied Velcro strips. The
UEGO controller should be mounted as flat as possible and should not be in a place where it will
be subjected to shock, water, or extreme heat.
Page 2
There are either two (30-2301) or three (30-2300) connectors protruding from the box. The long black cable(s) connect to the oxygen sensor(s). Ensure the routing to the sensor will not come in close contact with the exhaust. The 6 pin (8-pin on the 30-3300) rectangular connector plugs into the Power/Output harness. This connector provides power to the controller unit and also contains the sensor output(s).
These can be connected to the AEM Engine Management System (EMS) or many other
When connecting to an AEM EMS, Use the following pins for AFR #1 & AFR #2:
AEM EMS P/N AFR #1 Pin AFR #2 Pin
standalone engine management systems. When connecting to the EMS, the UEGO AMP outputs should be connected to the AFR#1 or AFR#2 inputs. The black wire is to be connected to battery negative (do not use the chassis as the power ground). The red wire is for switched +12 volts. This wire should be powered only when the ignition switch is “on”.
30-1000 D14 D16
30-1001 D14 D16
30-1002 D14 D16
30-1010 C16 C15
30-1012 C16 C15
30-1020 D7 D14
30-1100 B47 B48
30-1101 B47 B48
30-1120 B6 B14
30-1121 B6 B14
30-1130 B6 B14
30-1300 4 66
30-1310 76 75
30-1311 76 75
30-1312 76 75
30-1313 76 75
30-1400 29 43
30-1401 44 43
30-1710 2N 4J
30-1720 C3 D3
30-1800 C3 A2
When connecting to a third party engine management system, the 0-5 volt or 0-1 volt outpu
hould be connected to the analog O2 input of the ECU. Consult the documentation provided
with your ECU for detaile
t
s
d instructions.
Page 3
Installing the AEM Wideband O2 sensor kit
The 5 (7 on the 30-3300) wires hooked follow
Orange Sensor #1 0-5 Volt Output
White Sensor #1 0-1 Volt Output
Blue Sensor #2 0-5 Volt Output (on 30-2300 only)
Green Sensor #2 0-1 Volt Output (on 30-2300 only)
Brown Signal Ground (use only on system th a differential input, not the AEM EMS)
Red Switched +10 to +18 Volts (10 Am se Requi
Black Battery Ground
Oxygen Sensor
Typical production car O2 sensors rely on “nernst cell” technology, commonly called “Narrow
Band”, “2 wire”, “4 wire” and s erroneo describ “Wide Band”. This is a very
cost effective method that outputs a voltage based on the oxygen content of the gas being
sampled. It is accurate in the region surr etric operation and leaner.
Unfortunately, in the rich region where high performance engines usually operate, their accuracy
should be
up as
s:
s wi
p Fu
red)
sometime
usly
ed as
ounding stoichiom
and repeatability is virtually non-existent. Page 4
Characteristic curve of an nernst cell type O2 Sensor
The rich region output of a common O2 sensor is very temperature dependant, which renders it
useless if an accuracy gre diately obvious given the
ct that a single output voltage actually represents wildly different AFR’s depending on the
nregulated and unmeasured sensor temperature. These sensors were designed for operating
and for performance tuning they
re useless.
troller is the Bosch LSU4.2 Universal Exhaust Gas
ferred to as “laboratory grade” and
or you would find in your car. Its
type urrent pump” within the sensor itself to determine the actual
xygen concentration within the sensing element or, lacking any O2, it determines the amount of
to regain stoichiometric operation. The output is in the form of a very small
s process replaces the traditional “free air” calibration
rocedure when changing sensors and implements a sensor specific calibration for unparalleled
ccuracy.
ater than 1.5:1 AFR is desired. This is imme
fa
u
closed loop around the stoichiometric AFR (14.64 for gasoline),
a
The heart of the AEM Wideband con
Oxygen (UEGO) sensor. This type of sensor is commonly re
works on a different principle than the normal oxygen sens
unique design makes precision AFR measurement possible over the entire operating range.
UEGO sensors use a “c
o
oxygen required
current which varies depending on the air-fuel ratio. This is completely different from a normal oxygen sensor (1, 2 and 4 wire types) which directly output a voltage. The UEGO design allows measurement of the exact air fuel ratio over the entire operating range. Each AEM UEGO sensor is individually calibrated and a resistor integral to the connector body is laser trimmed with this value. Thi
p
a
Page 5
UEGO sensors laser etched calibration resistor
ed race fuel then you must mount the sensor at least 36 inches or more downstream
st port as all of these can cause the sensor to overheat. On turbocharged engines the
ation
, see
Sensor Placement A weld-in M18 X 1.5 boss is supplied for sensor installation. Mount the O2 sensor in the exhaust system at least 18 inches downstream from the exhaust port. If you anticipate high EGT’s (over 800C), run a turbocharger, run at high RPM for extended periods of time or plan on running leadf the exhau
o
UEGO sensor must be installed after the turbo charger, if not, the pressure differential will greatly effect the accuracy of the unit. In applications with a catalytic converter, the UEGO sensor must be mounted BEFORE the converter. In applications with an auxiliary air pump, the UEGO sensor must be mounted BEFORE the pump input to the exhaust stream. Installngle should be inclined at least 10° towards horizontal (electrical connection upwards
a
diagram) which prevents the collection of liquids between sensor housing and sensor element during the cold start phase. Minimum mounting angle for the UEGO Sensor
Page 6
Volts Lambda 0-5v AFR Gas 0-5v Volts Lambda 0-1v AFR Gas 0-1v
0.000 0.57 8.41 0.477 1.41 20.67
0.156 0.58 8.52 0.492 1.29 18.83
0.312 0.59 8.64 0.506 1.19 17.49
0.468 0.60 8.81 0.521 1.13 16.54
0.624 0.61 8.98 0.535 1.08 15.87
0.780 0.62 9.09 0.550 1.03 15.14
0.936 0.63 9.26 0.566 1.00 14.70
1.092 0.64 9.44 0.579 0.98 14.31
1.248 0.66 9.61 0.594 0.96 14.03
1.404 0.67 9.78 0.608 0.94 13.75
1.560 0.68 9.95 0.623 0.92 13.47
1.716 0.69 10.12 0.637 0.90 13.19
1.872 0.70 10.29 0.652 0.88 12.91
2.028 0.71
10.47 0.666 0.87 10.69 0.681 0.85
12.69
2.184 0.73 12.46
2.340 0.75 10.92 0.695 0.84 12.24
2.496 0.76 11.15 0.710 0.82 12.02
2.652 0.78 11.38 0.724 0.81 11.80 2.808 0.80 11.67 0.739 0.79 11.57 2.964 0.82 11.95 0.753 0.77 11.35 3.120 0.84 12.24 0.768 0.76 11.13 3.276 0.86 12.58 0.783 0.74 10.90 3.432 0.88 12.92 0.797 0.73 10.68 3.588 0.91 13.27 0.812 0.71 10.46 3.744 0.93 13.67 0.826 0.70 10.23 3.900 0.96 14.13 0.841 0.68 10.01 4.056 1.00 14.64 0.855 0.67 9.79 4.212 1.04 15.21 0.870 0.66 9.60 4.368 1.08 15.84 0.884 0.64 9.39
4.524 1.13 16.53 0.899 0.62 9.15
4.680 1.18 17.27 0.913 0.61 8.94
4.836 1.24 18.19 0.928 0.59 8.71
4.992 1.33 19.44 0.943 0.58 8.50
0-5 volt and 0-1 volt analog output calibrations
Gasoline AFR = Lambda * 14.65
Methanol AFR = Lambda * 6.47
Diesel AFR = Lambda * 14.5
Propane AFR = Lambda * 15.7
CNG AFR = Lambda * 14.5
Calculating the Air Fuel Ratio of common fuels from the Lambda value
Ethanol AFR = Lambda * 9.00
Page 7
s Ot V8.009.0010.000.000.501.003.504.004.505.00VoltsAFR (
Gas)0-1V AnautpuStoich7v Analog Otoich = 4.0
Air
Fuel Ratio (AFR) v
utpu
oltages
11.00
12.00
13.00
14.00
15.00
16.00
17.00
18.00
19.00
20.00
log O
t
= 0.5
0-5V
utput
S
v
1.502.002.503.00
Page 8
SPECIFICATIONS:
Controller
30-2301 30-2300
9 to 18 Volts
Supply Current (nominal): 1.3 amps 2.6 amps
UEGO Sensor Inputs: 1 2
0-5v “Rich to Lean” analog outputs: 1 2
0-1v “Lean to Rich” analog outputs: 1 2
Measuring Range: 0.55 to 1.3 Lambda
Harness & Connector T 120 C
emp Limit:
Sensor
Type: Bosch UEGO LSU4.2
Accuracy: +/- 0.7%
Exhaust Temp Limit: 1030 C
Cable & Protector Sleeve Temp Limit: 250 C
Connector Temp Limit: 120 C
Initial Warm-up Time: Less than 20 seconds
Weight: 80 grams
Heater Current: 1.2A at 12.0V (each sensor)
Mounting: M18 X 1.5 thread, Torque to 30 ft-lbs
80,000 km for Unleaded Fuel
50,000 km for Leaded Fuel 0.15g Pb/l
20,000 km for Leaded Fuel 0.40g Pb/l
Nominal Service Life:
10,000 km for Leaded Fuel 0.60g Pb/l
Notes:
The sensor contains a ceramic module and should not be subject to mechanical or thermal shock
or it may be damaged.
The sensor is not designed for operation on leaded fuels, doing so will dramatically shorten
sensor life.
Long term running in the rich region (Lambda < 0.95) will shorten sensor life.
High exhaust temperatures (over 850C) will shorten sensor life.
Engine oil consumption at a rate greater than 1 quart per1,000 miles will shorten sensor life.
Do not run the engine with the UEGO sensor installed without power applied to the controller
and the sensor plugged in.
Page 9
PARTS LIST:
Dual Channel UEGO Sensor Kit, P/N 30-2300
1 x Dual Channel UEGO Controller
2 x UEGO Sensor
1 x Flying Lead Harness
Single Channel UEGO Sensor Kit, P/N 30-2301
1 x Single Channel UEGO Controller
1 x O2 Sensor Bung & Plug
2 x AEM Stickers
REPLACEMENT OXYGEN SENSOR COMPONENTS
3 t UEGO Sensor (requires 30-2300 or 3 controller to use)
3 Bung, mild steel, welding requir
3 O2 Sensor Plug, mild steel
12 MONTH LIMITED WARRANTY
x AEM Stickers
x Velcro
x UEGO Sensor
x Velcro
0-2001 Replacemen
0-2301
5-4005 O2 Sensor
ed
5-4001
ine Management Inc. warrants to the consumer that all AEM High Performance products will be free
e original purchase.
EM’s option, when
kmanship. This warranty is limited to
the
not warranty the UEGO sensor, please contact Bosch directly for warranty claims.
be transportation prepaid and accompanied with dated proof of purchase. This
arranty applies only to the original purchaser of product and is non-transferable. All implied warranties shall be
limited in duration to the said 12 month warranty period. Improper use or installation, use for racing, accident,
abuse, unauthorized repairs or alterations voids this warranty. AEM disclaims any liability for consequential
damages due to breach of any written or implied warranty on all products manufactured by AEM. Warranty returns
will only be accepted by AEM when accompanied by a valid Return Goods Authorization (RGA) number. Credit for
defective products will be issued pending inspection. Product must be received by AEM within 30 days of the date
RGA is issued.
Please note that before we can issue an RGA for an EMS or UEGO System, it is first necessary for the installer or
end user to contact our EMS tech line at 1-800-423-0046 to discuss the problem. Most issues can be solved over the
phone. Under no circumstances should a system be returned or RGA requested before the above process transpires.
Advanced Eng
from defects in material and workmanship for a period of twelve (12) months from date of thProducts that fail within this 12 month warranty period will be repaired or replaced at A
determined by AEM that the product failed due to defects in material or wor
the repair or replacement of the AEM part. In no event shall this warranty exceed the original purchase price of
AEM part nor shall AEM be responsible for special, incidental or consequential damages or cost incurred due to the failure of this product. AEM doesarranty claims to AEM must
Ww
Page 10
Or you could check aempower.com :P
Old Nov 8, 2005 | 11:31 PM
thanks,
I read all that. The thing is I have AEM UEgo sensor and a gauge, nothing else. Gauge has 4 wires (2 for power BLK & Red) and 2 for output. THe question is where do I hook up those wires on the AEM EMS to use the wideband.??
Old Nov 9, 2005 | 04:48 AM
techause's Avatar
This might help. 'Add-a-circuit Mini'
In the fuse box:
#10 is switched 12v (10amp)
#17 is constant 12v(10amp)
Old Nov 9, 2005 | 04:52 AM
kmcconn9's Avatar
should have come with a box??
Old Nov 9, 2005 | 07:07 AM
bolsen's Avatar
Yea, check the forums at aempower.com. I have a post in there specifically asking the question you are. I'd look it up for you, but I'm at work
Old Nov 9, 2005 | 09:06 AM
Aem forums are not opperational at these times, the are moving to a different host service.
Idont need fuses, just where to splice in for AEM ems beeing able to read wideband info:?
Old Nov 14, 2005 | 07:16 PM
So, can anybody tell me which wire on the wideband sensor goes to which wire in the ECU harness? Seems that I cant get defenite answer for that.
thanks
Old Nov 15, 2005 | 09:39 AM
kcevo's Avatar
red is switched 12volts(put with an inline fuse), black is ground, white is the output to the ems, blue is unused
BTW, how's the car running or is it still rich? I thought you hooked this up before I sent you the EMS cal file?
Old Nov 15, 2005 | 10:33 AM
I did hook up the wideband gauge and all.
Also I just had it tuned by Al and now need some fine tuning.
Do you know which wire (color)on ecu Harness I need to tap in?
thanks
Old Nov 15, 2005 | 11:55 AM
kcevo's Avatar
pin 76, it's white. It's on the D plug, 6 over starting from left of the plug while looking directly into the EMS with the plug's still in it. The top part of the plug is the one with the thumb tab to remove it from the ECU. You can look the ecu pinout up if thru the AEM program file under instructions, the part number is 1313 for the ecu.
Old Nov 16, 2005 | 06:42 PM
Thanks, Chad C. Everything is working nice now
Old Nov 17, 2005 | 07:06 AM
kcevo's Avatar
No problem, glad I could help.
Old Oct 14, 2009 | 11:02 PM
80210's Avatar
I've got a concern...
I just hooked mine up. I spliced the power (red) into the red radio line. Granted I have a few other things connected to it it turns on and appears to work.
Heres my problem:
1. When I plug in the bosch sensor it gets hot in my hand... is it supposed to heat up?
2. Theres a wining noise that comes on right as I plug in the bosch sensor. As soon as I unplug the sensor the AEM gets power but the whining stops (sounds almost like my walbro!)
Anyways, any ideas? loose connection? not enough power for the bosch?
Old Oct 15, 2009 | 12:15 AM
MasterNater's Avatar
I can't help with the whining noise, but the sensor is suppose to get warm. It's just the sensor preheating.
