Megan Cat-back using stock cat problems!
I have the Megan cat-back which is 3" with no taper, how do I mount it to the stock cat which is 2.5"? Does it have to be cut or modified? Anyone else with this problem? I don't want to add anymore to the exhaust (cat-delete,3" cat, or another downpipe). Please help!!!!!!!!!! Thanks
I have the full megan turbo back. when I first got it the test pipe was on back order. I put the rest on anyway with the stock cat. I didn't have any problems with the cat back part. I did have to enlarge the bolt holes on the dp side though.
If I put a new stock cat gasket on and bolt the exhaust to it, the exhaust flange has enough coverage to prevent leak? What did all you Megan cat-back only exhaust owners do? (that diden't add the dp and testpipe)?
i put a 3" testpipe on a stock exhaust and everything worked fine. i know this is kinda backwards from what ur doing, but same difference. everything really should bolt up fine. have u gone underneath the car and tried it yet, or ur just talking about it?
You will need to dremel about 2mm out of the inside of the Megan bolt holes... with the OE cat gasket, it should not leak. I ran to inspection this way. The OE cat chokes flow on a Turbo back enough to easily "feel" though.
WTT[Mid-Atlantic]: Megan catback for another catback
Locdizzel
Jun 2, 2016 07:26 AM
smp3000
Aug 11, 2005 07:51 AM
nine4surfah
Aug 15, 2003 03:05 PM
