Driveline Noise Help
Old Nov 15, 2005 | 08:02 AM
russjnco's Avatar
Thought I would see if I could gain some extra insight as I'm at a total loss as to what this noise is. From about 20 mph to 35 mph I'm getting this droaning noise, it's not a whine or metallic and it's definitely not a grinding type noise. Doesn't matter which gear it's in nor does turning left or right seem to effect it. Then above 35 it goes away. I've checked all the CV boots, they check out okay and there's no endplay in the wheel bearings. Any ideas?
Old Nov 15, 2005 | 08:17 AM
chmodlf's Avatar
Mine does the same thing. The trannys made by Getrag are just noisy. If you take it to a dealer they will say that it is normal. If the noise is really severe you may have problems that are more than just "normal".
Old Nov 15, 2005 | 08:21 AM
russjnco's Avatar
Glad to know I'm no the only one. I wouldn't say that it's severe, at least not yet!
Old Nov 15, 2005 | 08:45 AM
rsboy's Avatar
Try changing out your tranny fluids. I had the Royal Purple and now I have a Redline cocktail my friend made and the car drives fine and no major "noises" from the tranny. The car is just noisy as hell, generally, but that's something we can't do anything about.
Maybe dynamat helps.
Old Nov 15, 2005 | 09:10 AM
russjnco's Avatar
I wish it was fluids.......I changed out the gearbox, t-case and rear diff and it's still there. I used the Redline cocktail for the gearbox of 2 parts Mt-90 and 1 part MTL and diagqueen for the others.
Old Nov 15, 2005 | 02:48 PM
russjnco's Avatar
bump
Old Nov 17, 2005 | 07:11 AM
russjnco's Avatar
bump to see if anyone has more info......
Old Nov 17, 2005 | 07:24 AM
Jamdown's Avatar
I have a similar noise and I'm told it is normal. I am gonna get my car serviced soon so I'll confirm then too.
Try holding your clutch down a bit longer when shifting (up or down)...you may be the same noise then too like I do.
I change my fluids way more than I need to and it is shifting correctly, but it is wierd.
Old Nov 17, 2005 | 07:35 AM
russjnco's Avatar
It's definitely there when I push the clutch in and coast a little. It's sounding more and more like this is normal. Weird but normal.........
Old Nov 17, 2005 | 07:51 AM
rsboy's Avatar
You've had the car since new? If so, is this something that just recently occurred?
Old Nov 17, 2005 | 08:46 AM
b204dr's Avatar
The whine is the center diff as i understand it and is NORMAL ... myne did this with zero miles on it
Old Nov 17, 2005 | 10:27 AM
russjnco's Avatar
It started up about three weeks ago so it's fairly recent. I've had the car since new and it just turned over 19,000 miles.
