Clutch change! Stock flywheel....
Old Nov 16, 2005 | 11:54 PM
QwikEVO's Avatar
Resurface or get an aftermarket?
Just trying to do what's best for the car. I don't want to have to crack the tranny open again for a stupid stock flywheel, nor do I want to spend money I don't have to.
Opinions?
For mods I have 3" TBE, Hard I/C pipes, CAI, EBC @ 22psi, Dynoflash, Walbro 255, Greddy BOV
I plan on getting cams/gears/AFC in the future. Should I just get the flywheel?
I'm looking at the Gruppe-S deal with the ACT clutch/CCI flywheel for $725 shipped. What quality is CCI? Never heard of them....
Old Nov 17, 2005 | 07:40 AM
ACTman's Avatar
It depends on how hard you are on the parts. The stock flywheel is a good part. It is about 14.5lbs which is pretty light, but it is a bit thin which makes it prone to warp for those that tend to ride the clutch. I can't speak for the quality of the CCI part. I have no experience with it. I don't even know if it is aluminum or steel. Our flywheel which will be available in two weights is going to be very nice; much thicker than stock and yet still lighter, but they won't be available for about 3 weeks.
Old Nov 17, 2005 | 07:42 AM
04 rs's Avatar
so the act flywheel will be available in 3 weeks???? like 100% for sure??
Old Nov 17, 2005 | 07:43 AM
turboDan's Avatar
I had my stocker resurfaced,but it is some hard #hit.The shop that resurfaced had to use their diamond wheel as their normal wheel chattered bad.Only good for about 1 resurface and depending on how much material is removed may not even be good with 1 resurface.
Old Nov 17, 2005 | 08:06 AM
ACTman's Avatar
Not as sure as death and taxes, but pretty close. I can check later today to find out more if you like.
Old Nov 17, 2005 | 08:07 AM
04 rs's Avatar
can you let me know
Old Nov 17, 2005 | 08:09 AM
ACTman's Avatar
We cut them all the time with no trouble. It is not a matter of hardness. The problem is that you shouldn't use the same grade stone as you do with cast iron. It doesn't take diamond though.
nhsean69
23
Mar 15, 2010 02:30 PM
maperformance
Evo 'For Sale' Engine Internals and Drivetrain
219
May 2, 2009 09:08 AM
JDMonster
May 2, 2007 09:50 PM
BOOSTEZ
22
Jan 5, 2006 05:41 PM
Gruppe-S
Sep 10, 2005 02:11 AM
