evo internals into turbo 2g eclipse??
Old Nov 17, 2005 | 07:55 AM
TeenEVOwner's Avatar
I have an 2003 Evolution and I am rebuilding it this winter, and for my daily driver I am purchasing a 1997-99 turbo eclipse... I was wondering if when I take out the internals of the evo, I can just swap them into the eclipse. I was told that when you go to put in new pistons and rods, that you need to enlarge the cylinder by a fraction, or something to that degree....and since both engines are 2.0 liters, would the pistons and rods still work, or would I need a slightly bigger set?? and no I am not going stroker, so that isnt an option (even though it would be nice)... Sorry for the noob question, I did do a search before looking into this however, and I think I can w/out much problem, just wanted to get some directed answers...
thanks in advance!!!
Old Nov 17, 2005 | 08:11 AM
Chris@nolimitmotors's Avatar
the valve reliefs on the evo pistons dont match up with the eclipse motor
Old Nov 17, 2005 | 08:13 AM
Evo 8-2003+ 9.0:1 compression (Evo 8 valve pockets opposite of 2nd gen)
thats what it says on wiseco's listong
Old Nov 17, 2005 | 11:35 AM
05SilverEvoVIII's Avatar
Wow, i was thinking that this would be a good idea if it would work man that sucks.
Old Nov 17, 2005 | 05:25 PM
timzcat's Avatar
Evo bore is 85mm. DSM bore for that year I believe was 85.5mm. Either way I know it's not the same bore.
Old Nov 17, 2005 | 07:41 PM
eclipse bore is the same 85mm.
Igaly1021
Aug 15, 2016 07:56 PM
Sheroku
Lancer Engine Tech
Mar 23, 2016 11:25 AM
Turbotech
Lancer Aftermarket Forced Induction Tech
40
May 26, 2014 01:39 PM
migueralliart
15
Jun 1, 2007 10:01 AM
VTEC Killer
18
Apr 29, 2005 04:17 PM
