Which air and fuel ratio?
Old Nov 18, 2005 | 10:18 AM
tequila083's Avatar
With my modifications (see my signature)which a/f radio should be safe to run with open throttle (to the floor). I think i am to rich, in 5 gear i am running about 10.1 and i am going to lean a little bit. i am using 93 octane.
Old Nov 18, 2005 | 10:21 AM
ez's Avatar
ez
11.5 to redline is generally safe. If you are running 10.1, you will see nice gains from leaning to 11.5
You need some logging gear to see what really going on. What do you have now?
Old Nov 18, 2005 | 10:22 AM
djmikeymike's Avatar
14.5 before boost around 11 on boost
Old Nov 18, 2005 | 01:01 PM
Boost Addict's Avatar
Absolutly 11.5:1 is nice and safe for WOT.
Old Nov 18, 2005 | 03:54 PM
Nad1370's Avatar
Wait...let me get this straight. Your going to run your car to 150+ mph to tune it ? Can you say heat soak .Hope your doing this on a dyno.
I would tune it in 4th maybe 3rd.
Old Nov 19, 2005 | 08:27 AM
tune in 3rd gear........you will notice the your a/fs and higher in 1st gear and lower in 5th gear...... in at about 10.7 in 3rd........ 1st im about 11.4........ and 10.1 in 5th
Old Nov 19, 2005 | 08:53 AM
mchuang's Avatar
If you are in hot weather..I would say 11.1 if you are using stock ecu...ecu has a correction factor I am assuming and when the temperature changes and it gets colder outside the ecu will lean the car out...therefore you have room to compensate for that correction factor.
Old Nov 19, 2005 | 09:57 AM
twinscrewed's Avatar
10.1 is pretty rich. 11.1 to 11.5 is what you should shoot for.
Old Nov 19, 2005 | 12:55 PM
fsugatorbait's Avatar
Tune in 3rd to ~11.3 - 11.4 a/f.
Old Nov 19, 2005 | 01:01 PM
DarksideEng's Avatar
I'de go for 11.8. No higher than 12.0 though, just to be safe with the colder weather. 12.0 is safe but I would go a little under to be even more safe. No need to be around the tens... ie. 11.0-11.1. I think thats too rich.
joeymia's Avatar
11.1 is safe for 91oct and 11.5 is on the aggressive on 93 octane. I run alky full time at 11.5 on the street, at the track I go to 12.0 while on alky.
Old Nov 19, 2005 | 01:02 PM
joeymia's Avatar
anything above 11.5 on just regular 93 pump is already pushing it... your engine is going to take some abuse from high EGT's if you run that everyday.
Old Nov 19, 2005 | 01:05 PM
How do you know? Why do you think that? I think it would depend on what mods he has, ie. 3" exhaust, larger o2 housing, etc.
Edit*** I just actually looked at his mods and he does have a turboback exhaust. He does not however have the larger o2 housing, or he doesnt list it. We dont know his EGT's so theres no way to know.
Old Nov 19, 2005 | 01:08 PM
joeymia's Avatar
It doesn't matter what mods you have. That afr is going to produce high EGT's overtime you will melt a piston. I am assuming he is going to tune for daily driving. Anything over 11.5 without alky or race gas is pushing it on 93 octane IMO.
Old Nov 19, 2005 | 01:14 PM
Ok, we I will tune for what I want and you can tune for what you want. I dont want to argue with you, its kinda pointless. Plus, I might need your help someday with the MAFT pro translator lol, so I dont want to argue. 11.5 is safer, but I'm just saying 11.8 is what I go for and I believe its safe.
