MSD DIS-2 installation question/problems
Old Nov 22, 2005 | 06:48 AM
joeymia's Avatar
I am running .28 gap right now and everything seems to be working great. I have a concern about the DSM ignitor. It took me a while to locate the part. I was wondering if there was some kind of other ignitor that would work well with my setup. Maybe something I can easily get at a GM parts store.
Jack:
Will those Viper ignitors work for me?
Old Nov 22, 2005 | 10:57 AM
PPI's Avatar
PPI
yeah, .28 gap is working good for me....as i have heard .28 to .30 be the norm with ignition amplifiers and meth. at hight boost.
did you not weld a bung onto your i/c pipe for your IAT sensor? Looks like you threaded it right onto the alum. piping.....yikes?!
Old Nov 22, 2005 | 12:35 PM
joeymia's Avatar
yeah its threaded in the pipe and has some locktite red. Trust me its not going to come loose
Old Nov 22, 2005 | 10:21 PM
joeymia's Avatar
I posted some questions on the msd forums. One of their techs had this to say
"When you connect the DIS 2, make sure the ECU's output is set at a constant charge @ 2 to 2.5Ms at battery amplitude."
WTF does that mean. Someone please translate that english for me
Old Sep 8, 2006 | 10:36 AM
Noogles's Avatar
Awesome Info!
Can The MSD Dodge Blaster coil replace the gm twin tower coils?
Old Sep 8, 2006 | 10:52 AM
MalibuJack's Avatar
Originally Posted by Noogles
Awesome Info!
Yep..
Talk about reviving an old thread..
Old Sep 8, 2006 | 11:58 AM
Noogles's Avatar
Originally Posted by MalibuJack
Yep..
Informative thread like this one should be re-introduced into the community every once in a while.
Jack,
I'm not quite sure if i understand all i'm going to need,
4 coils
4 plugs wires
1 MSD Box
4 pigtales
What Ignitor Will i need?
Am i missing anything?
Old Sep 8, 2006 | 12:28 PM
joeymia's Avatar
you can use a DSM ignitor but I have gone thru 3 of them. They don't last very long. He is using a dodge viper ignitor but I have no clue what the part number is.
Old Sep 8, 2006 | 12:29 PM
joeymia's Avatar
btw i don't recommend this for a daily driver. the MSD has a misfire at 3k that you can't do anything about. It gets kind of annoying after a while. At WOT is where this thing shines.
Old Sep 8, 2006 | 12:36 PM
ExViTermini's Avatar
exactly why I'm still on stock ignition, took that **** off and sold it a while back. Except the MSD box. If anyone wants it I'll let ti go cheap.
Old Sep 8, 2006 | 12:43 PM
Noogles's Avatar
Joey,
Do you have a diagram for wiring the ignitor to the stock harness?
Old Sep 8, 2006 | 12:52 PM
joeymia's Avatar
everything you need to wire this up is in the first post. Just don't connect the tach driver.
Old Sep 8, 2006 | 12:54 PM
joeymia's Avatar
well i still use it when i go autox or something but i hate driving around with it. to make matters worse my stationary rev limiter doesn't work because of a bad speed sensor. So the only time i can ever launch properly is with this connected.
Old Sep 8, 2006 | 01:06 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
guys for anyone intersted i have a msd dis2 , 300m coils, custom plate to hold them, 1g ignitor and even a new aem cdi unit (aem unit isn't needed to use the system...just needs the wiring finished and everything is virtually new. PM me with offers
Dave
Old Sep 8, 2006 | 01:09 PM
Noogles's Avatar
Dave
What setup are you replacing it with?
Shoot me a PM regarding the $$$
