The not-so-offical EVO 9 ECU tuning thread
Old Dec 27, 2005 | 10:33 AM
  #406
David Buschur's Avatar
The BR330 hp levels would not be hard to duplicate at all if you didn't care about warranty or removing the stock cat. The hard part is making the power through the stock cat and without a manual boost controller.
The re-tune is where most of the power lies.
David Buschur
www.buschurracing.com
Old Dec 27, 2005 | 10:35 AM
  #407
What we do for the hp numbers is this. Say a stock EVO is rated at 286 and then we put it on the dyno and find it makes 210. In order to claim a 50 or 70 hp increase we have to increase the whp by 50 or 70 whp. That is how we came up with our BR330 and BR350 ratings.
David Buschur
Old Dec 27, 2005 | 10:37 AM
  #408
meanmud's Avatar
Appreciate your responses
Old Dec 27, 2005 | 10:45 AM
  #409
meanmud's Avatar
I think you're making the mistake of trying to equate the package name with BHP. Depending on what drivetrain loss you prefer to use or what type of dyno you think is the standard, you could make the case that IXs are already at 330bhp in stock form.
330bhp with an 18% drivetrain loss = 270whp, which is what we're seeing on Dynojets.
The BR330 package on IXs is getting them closer to 330 WHEEL HP, not crank HP. Hope this helps.
Appreciate your take on it, but now that Buschur is using MD's, that ain't jiving
Old Dec 27, 2005 | 10:57 AM
  #410
Warrtalon's Avatar
Oh, it still jives. Dave mentioned this after doing the comparison with Switzer's Dynojet when the same car did 282whp on the Dynojet and 218whp on the MD.
Old Dec 27, 2005 | 11:07 AM
  #411
meanmud's Avatar
What I mean is that the cars will not be putting 330whp & 350whp on Dave's MD
Old Dec 27, 2005 | 02:31 PM
  #412
Cloud's Avatar
Are you stating that the BR330 package on the IXs are putting down almost 330whp of Dave's super low reading Mustang Dyno? Care posting a dyno sheet up? What does the BR330 package include?
Old Dec 28, 2005 | 12:56 AM
  #413
shiv@vishnu's Avatar
Originally Posted by SaabTuner
That's pretty much what I figured. Mitsubishi might have had youngin's with MBC's in mind when setting the timing/massflow/RPM curves. By pulling timing as massflow goes up, it's less-likely to run into knock as soon. Probably not a bad idea. Figured the MIVEC was part of it too. The best of both worlds; boost-optimalized cam-timing when under boost, and naturally aspirated optimalized cam timing when cruising. It's like the benefits of cam gears x eleventybillion.
Is there any way I could coax you into posting a few of the stock ECU's timing/RPM/load maps? I think that would be kinda cool. Obviously not any tuned maps.
Anyhoo ... keep up the good work.
FWIW, just started tuning another IX today. It belongs to Greg Vandermark who is the Motorsports Director for Toyo Tires. The car came to us equipped with a 3" cat-back exhaust and a 3" downpipe (running stock cat). It baselined, before the flash, at 233-235whp. Pretty much identical to all the 100% stock IXs we've tested. Peak curve is also very similar with the exception of slightly improvements to spool up. And since the factory ECU's boost control is MAF-based, it does adjust boost pressures to hit the desired airflow targets. That's another reason that VE enhancing bolt-ons don't really seem to do too much to improve power when running stock ECU code.
And yep, i'll be happy to post up stock timing/fuel maps. Can't do it until tomorrow though. I don't have access to my laptop right now
Cheers,
shiv
Old Dec 28, 2005 | 07:03 AM
  #414
honda-guy's Avatar
this post might have ruin my plan to wait for the Evo X
Old Dec 28, 2005 | 08:13 AM
  #415
SaabTuner's Avatar
Cheers,
shiv
Aha! So Mitsubishi is doing what Saab did with Trionic 7. T7 also reduces timing dramatically if you go over the air-flow targets. And, to reach the airflow targets at high altitude, it boost higher. But when you increase the VE, it boosts lower. (Same airflow values, always, if it can.) Veeeeddy interestink.
Except the T7 ECU will "freak out" if your spool up is too quick and it will learn to target lower airflow/RPM values. Which ends up meaning that, in order to modify the engine without losing power, you have to first find a turbine housing with a larger A/R ratio. AND, because T7 uses an electronic throttle body, if you try to use an MBC, it will close the throttle on you to limit boost! It's too smart for its own good. The upshot is that you can drive the car with the boost control solenoid disconnected, and because there is still a MAP sensor as well, you can drive it without the MAF sensor. Talk about redundancies.
Ok, so it's settled, when I get out of school, I'm buying an Evo IX and Shiv is going to give me a free reflash ... and a million dollars.
Old Dec 28, 2005 | 08:46 AM
  #416
DynoFlash's Avatar
Cheers,
shiv
If all the gentleman added was a 3" exhuast - I would not expect huge power gains on the stock boost. However - with the addition of some form of boost control - ecu flash or otherwise then there would be some gains over stock.
In the case of the Buschur BR350 car with cat back exhuast and intake with ported 02 housing and manifold there were significant gains i9n power with just the addition of the parts without tuning.
BOOST CONTROL is a key though with the Evo as the MAF sesnor based boost calaculations will lower the boost level to some extent as you free up VE. (nothing a reflash can't cure or MBC). NOTE - this is nothing new to the IX - the 8 used the same boost system - only difference is the boost targets are a bit lower in the IX.
Old Dec 28, 2005 | 09:13 AM
  #417
Warrtalon's Avatar
No...hell no. I'm referring to the standard when comparing/stating WHP figures around the country...Dynojet. 330 on Dave's MD is good for 124mph traps on his RS.
Basically, the BR330 packages are putting out close to 330whp on a Dynojet.
Old Jan 2, 2006 | 08:29 PM
  #418
DJPurpose's Avatar
anything new?
Bump. Any more news for the IX Tune? Are you doing IX tunes yet? If so, how much?
Old Jan 2, 2006 | 08:37 PM
  #419
edwin's Avatar
I want to see 124MPH with 330whp!!
Old Jan 2, 2006 | 09:21 PM
  #420
Boosted AWD's Avatar
Shave about 1000 pounds from your Evo
