comp cams????
Old Nov 20, 2005 | 12:54 PM
superflyevo's Avatar
comp cams????
i was jus woundering if anyone had any experance with comp cams
i did a search, the last post was over a year or soo ago
figured some has used them sence then
thanks
Old Nov 20, 2005 | 01:42 PM
evo0486t's Avatar
i am getting mine puttin 2moworow or early tuesday so ill let u know....
Old Nov 20, 2005 | 03:03 PM
what grind did u get
Old Nov 20, 2005 | 04:13 PM
evo0486t's Avatar
264int
.434 valve lift
265exh
.411 valve lift
hopefully ill be satisfied... the gyuz from TT told me they installed them in a couple of EVO s already and they make more power than the HKS 280s... so hope it will be good...
Old Nov 20, 2005 | 04:20 PM
dude's Avatar
I've got the stage 2 Comp Cams, can't remember the specs offhand, but with a Vishnu Stage 1+ car I trap repeatable 108.xx mph in the quarter with really crappy 2.2+ 60 ft times on the stock clutch and 93 octane. They are very lopey at idle, with mine set at -3/-2 but I like it that way. Hope that helps you out a little.
Old Nov 20, 2005 | 04:23 PM
evo0486t's Avatar
thanx for your info... hope we have the same cam stages .. cause i like the idle when its lopey... ...
Old Nov 20, 2005 | 04:25 PM
Fa$[- a$ $hi[-'s Avatar
Where can we get a set of those? I always just see hks, gcs, or some other brand. How much are these a set?.....forget it found it.
evo0486t's Avatar
and plus i told the guyz from TT that i wanted mostely top end power... i don't really care about spool up and etc... and they requested these so ... i am hoping for the best..
Old Feb 18, 2006 | 08:49 AM
EMR8's Avatar
Any updates on these cams. I've searched BTW. Not much info, i orderd mine plus springs and retainers. Please share your experience!
Old Feb 18, 2006 | 09:09 AM
TrinaBabe's Avatar
Comp cams have been used in American cars for decades. DSMs have been using them for quite some time as well... technically the same duration (272/272) with the comps would be more aggressive if you look at all the specs. I believe the very aggressive ones require springs. Personally I am going to swap to comps when I pull mine apart to install the springs.
Old Feb 18, 2006 | 09:18 AM
EMR8's Avatar
I compared the hard #'s of these and the HKS and found that the Comp cams had a higher lift but the HKS's had a longer duration, so they kinda equal each other out. But i've heard that the comps make more power than the HKS. Both advertised as 272/272.
