Venting stock mr valve to atmosphere
Old Nov 21, 2005 | 06:16 PM
Joeballz's Avatar
this is a stupid question which i pretty much know the answer to but i have a jdm evo mr diverter valve. im getting a dynoflash soon. i want to know if i can vent my diverter valve to the atmosphere? thanks.
Old Nov 21, 2005 | 06:20 PM
quiksilverevo26's Avatar
you gotta be kidding right? It will make noise but you're gonna sacrafice power. Don't be stupid and try to be mr fast and furious.
Old Nov 21, 2005 | 06:22 PM
dbdude's Avatar
Thats ghetto. Buy a rael BOV that vents to atmosphere.
Old Nov 21, 2005 | 06:23 PM
Jim_Patterson's Avatar
Dont vent its rice.
Old Nov 21, 2005 | 06:24 PM
Joeballz's Avatar
right
Old Nov 21, 2005 | 06:25 PM
You talking to me?
Venting into the atmosphere its ricey and it hurts idle, performance.
Old Nov 21, 2005 | 06:26 PM
Joeballz's Avatar
right u can say its ghetto but considering its 120$ vs 300$, to me it doesnt make sense when they can both do the same thing. plus my friend had a 2g eclipse with a 1g crushed and it sounded pretty damn good when it was vented to the atmosphere and that might be cheap but many people did it with the eclipse because 1gs were stronger, and the jdm evo mr valve is supoupposedly stronger than the stock evo 8 from what i here.
Old Nov 21, 2005 | 06:28 PM
Jared622's Avatar
Ok here I will lay it down a little better then calling it ricey. The reason he is saying that is because are cars rely on a MAF sensor. The reason the valves have to plumb back into the intake pipe to keep this sensor happy. If you were to vent everytime you get on the car and clutch it real fast the idle will either drop way down or the car will just flat out die. VTA is just not a good thing to do and it will hurt the performance of your car. If you want the cool noise as well go with a dual vent bov or get a greddy type rs and have the whistle noise. Hope this helps.
Old Nov 21, 2005 | 06:31 PM
EVO316's Avatar
Don't VTA because you are still running the stock MAF. What is going to happen is that when you vent, that air has already been accounted for, so it will cause a very rich condition.
This will hurt your performance!!!!! Just stay with what you got. If you do want some sound get an intake (but make sure to tune it). Even getting an intake won't give you much noise or hp, since it will need to be tuned because it causes the MAF to read very unaccurately.
Joeballz's Avatar
i appreciate your advice, but i have another question if i VTA and get a dynoflash it will be fine correct or do you still lose horsepower either way? and lets say i dont VTA should i still buy a jdm evo mr or another brand, or leave the stock one?
Old Nov 21, 2005 | 06:34 PM
taenaive's Avatar
only problem for doing that is the stock bov opens little under the vaccum and leaks little bit on any boost level. you can try and let us know. it should be easy, just gotta have a plug for the intake.
Old Nov 21, 2005 | 06:36 PM
EVO316's Avatar
Ok i'm assuming you have an evo 8 with the stock plasitc diverter valve. Then YES, do change it out for the JDM MR unit, its cheaper than other ones and holds boost great. AND DONT TRY TO VTA IT, just recirculate it that is what it's made for.
Old Nov 21, 2005 | 06:40 PM
dsmythe2's Avatar
Thumbs down
Flash or no flash, piggyback ecu, whatever. As long as you have the MAF hooked up and functioning to meter your airflow, VTA will rob you of power by expelling air that the MAF is telling the ECU should be in the intake. Don't VTA unless you have a stand alone that does not use the MAF.
Old Nov 21, 2005 | 06:51 PM
ez's Avatar
ez
...as I stop and look both ways for Warrtalon....
this is a stupid question which i pretty much know the answer to but i have a jdm evo mr diverter valve. im getting a dynoflash soon. i want to know if i can vent my diverter valve to the atmosphere to make the bov noise? i know the noise doesnt do anything but like everyone else i think it sounds cool. thanks.
Old Nov 21, 2005 | 06:56 PM
Warrtalon's Avatar
Yeah, it'll work great. Go for it. The noise is the most important reason to have a BOV anyway.
Just curious, who/what gave you the idea that a tune had anything to do with being able to VTA? Did you get intakes and BOVs mixed up? A tune will allow you to run an aftermarket open-air intake, but a tune doesn't have anything to do with venting to atmosphere.
