Ignition amplifier + alky injection
Old Nov 22, 2005 | 05:18 PM
SlowCar's Avatar
Just wondering how many who has alky also has some sort of ignition amplifier like the HKS DLI II? I had a problem boosting over 23 psi...think that the water is putting the fire out or maybe the increase charge density is making it harder for the arc to leap the gap.
Old Nov 22, 2005 | 05:51 PM
Chris@nolimitmotors's Avatar
i ahev the dli2, but i have a friend/customer and my co worker both run 30 psi daily with NGK BPR8ES. with no problems. the only difference is I run a .028 gap and they have to run .022. Its a good idea but probably not your problem
Old Nov 22, 2005 | 05:55 PM
smokedmustang's Avatar
I have the same setup with 100% VP alky, and the HKS DLI II. the plugs gapped out of the box at .030, I put them down to .026 and the problem went away. how often do you change the plugs? what is the gap?
Old Nov 22, 2005 | 06:03 PM
SlowCar's Avatar
i got the ngk iridiums 7ix......changed it less than ~10K miles ago.....i think. I need one. There is a XS engineering one out there for less......any good?
Old Nov 22, 2005 | 06:17 PM
PPI's Avatar
PPI
meth, bpr8es plugs at .28 and hks amp...... runs great
Old Nov 22, 2005 | 06:19 PM
spyonu2007's Avatar
Meth Bpr8es .028 and Aem's ignition amp on msd coils, @ 25-30psi. Runs awesome.
Old Nov 22, 2005 | 07:16 PM
bishiboy's Avatar
I have Meth/H2O mix (running about 15% meth to fuel ratio), boosting to 25-28, redline at 8000 using my home built COP.
I've run my NGKBPR7EIX as big as .035 without a miss for a month. I'm running them at .030 now. Took them out after a few weeks, looked good as new.
I used to get the high boost/rpm miss and had to gap down to .022 and still had occaional miss and idled like crap.
Pale Horse
Dec 14, 2013 03:56 PM
PATRICK B.
E85 / Ethanol
10
Aug 28, 2008 03:39 PM
Trueno86
Oct 10, 2005 04:40 PM
PVD04
Sep 12, 2005 10:34 AM
AndyC
19
Apr 26, 2005 04:09 PM
