Ignition amplifier needed when using E85
Old Aug 27, 2008 | 08:35 AM
PATRICK B.'s Avatar
Just wondering if people are finding the need to use a cop set-up or add'l amplifier regardless of turbo size/boost pressure w/ E85?
From my experience all Evo's react differently but just trying to get an idea.
I believe Lucas English runs the SparkTech COP.
Anyone else have something to share?
Old Aug 27, 2008 | 09:21 AM
Jim in Tucson's Avatar
Not needed. I'm running 28psi with copper plugs gapped at 0.020". Works like a charm!
That said, would it "work" even better with more spark? Perhaps. I'd love to see an E85 shop do some back-to-back tests on ignition options.
Old Aug 27, 2008 | 09:24 AM
Lucas English's Avatar
The CDI is very nice but not needed like Jim said. I used run 33psi spikes on stock ignition at .019-.020 gap with no problems. The only things is I was putting plugs in the car ever 1000mi or so depending on how I drove it. With the the CDI I have yet to put new plugs in running a .022 gap.
Old Aug 27, 2008 | 09:40 PM
Is this on the IX turbo? I had always heard that 28psi was the magic number. Is there really any extra power to be had at higher psi? At what psi does the power actually begin to level off?
Thanks...
Old Aug 27, 2008 | 10:07 PM
Yes its a IX turbo. At the track it spikes 28psi and falls to 24psi. On the street the same setting will spike 33psi in the 3-5k range.
Old Aug 27, 2008 | 11:00 PM
PeteyTurbo's Avatar
At the track I run 26-27psi spike.All original ignition and plugs from an 05, never had a misfire yet.
Old Aug 28, 2008 | 01:04 AM
RazorLab's Avatar
Thanks...
You will get more peak torque and a little more area under the curve 4k to 6k or so. Up top the peak hp will be about the same as it can only flow so much there.
Old Aug 28, 2008 | 02:46 PM
dsmfan95's Avatar
I'm not running an amplifier. BPR8ES' gapped to .020"
Old Aug 28, 2008 | 02:58 PM
EvoIXMR's Avatar
IS 0.020 the gap? I have mine gapped at 0.024. My car does have an XS engineering ignition amplifier installed by the previous owner...
Old Aug 28, 2008 | 03:03 PM
AF-Evo8's Avatar
the gap is very dependent on what turbo you're running, bigger turbo's like 35-37r move a lot of air and you tend to have more of a need for COP or an ignition amp.
Old Aug 28, 2008 | 03:39 PM
bzzbee2's Avatar
.020.. interesting.. im gapped at .026 and running great.
NJ_evoIXgsr
Mar 9, 2017 05:57 PM
EKtoEvoX
Dec 9, 2014 01:02 PM
an2ny
Apr 1, 2014 11:00 AM
Srt4...
Jun 25, 2011 03:02 PM
PVD04
Sep 12, 2005 10:34 AM
