Using the radio without an amplifier.
Old Mar 24, 2014 | 10:49 AM
an2ny's Avatar
I have GSR with the Rockford Fosgate system (no navigation)
I would like to remove the OEM amplifier under the seat, but retain the radio sound.
Is there a wire/ harness that I need to be able to use the radio without an amplifier?
Thanks!
Old Mar 24, 2014 | 10:51 PM
Gqracer's Avatar
The oem amp has two harness plug. One output side and the other is the input side. Connect the output side to the input side. Make sure u identify the power wire and ignition wire first. Good luck.
Old Mar 25, 2014 | 06:39 AM
an2ny's Avatar
Correct there are 2 wires/ harness input to the amp and output from the amp like you mentioned. So I can just connect the 2 harness plugs together?
I do not know anything about stereo/ audio systems; I just want to lose the amp weight.
“Make sure u identify the power wire and ignition wire first” what do you mean by this? Are these other wires?, are these part of the harness?
Thanks!
Old Mar 25, 2014 | 02:51 PM
ikt's Avatar
ikt
Thanks!
cannot be done, the in dash unit has no output.
the factory amp weighs very little tho.
Old Mar 26, 2014 | 09:20 AM
Gqracer's Avatar
The head unit only has two channel out put wire which leads back to one of the harness that plugs into the amp. However, the other harness contains the speaker wires. The amp then will split it into a six channel or seven channel for the subwoofer option. You need to id the wires from the DIY thread on the forum and combine the four speaker wires into the two channel output wire. Do not hook up the tweets unless u have a passive crossover to filter out the low frequency because it will blow the tweets.
Old Mar 27, 2014 | 08:08 AM
an2ny's Avatar
Thanks!
I guess I will put it back in… it was about 4 lbs anyway.
Old Apr 1, 2014 | 11:00 AM
ikt's Avatar
ikt
what? no!
it's a signal wire not an amplified output, and if you combine 4 speaker wires into one output, you will get a .25ohm load and fry the headunit.
rsjust2nice
Mar 29, 2016 08:40 AM
d3r3k
10
May 6, 2014 11:05 AM
gullie667
Feb 10, 2010 11:06 AM
Enkrypter_DJ
12
Jan 16, 2010 05:40 PM
SophieSleeps
10
Jun 12, 2007 07:22 AM
