ecutec reflash and gt30r?
Old Nov 23, 2005 | 04:35 AM
aps's Avatar
aps
Guys can ı use my 30r without standalone because ı m using ecutec reflash.Have you got any bad experience between maf and gt30 series turbos?Is that maf enough to use?
Old Nov 23, 2005 | 04:59 AM
Ultimate CC's Avatar
My buddy runs a GT30r on a UTEC which is very similar in the way a reflash works. He is still running stock MAF with no problem as well.
Old Nov 23, 2005 | 05:11 AM
an0ther's Avatar
dont quote me on this but I have heard that the stock maf is good to about 430 hp
Old Nov 23, 2005 | 05:56 AM
It is definitely benefitial to go with speed density especially with a larger turbo I was just saying that my friend runs MAF still with no problem.
Old Nov 23, 2005 | 05:59 AM
SwiftEVO's Avatar
I ran my 30r with a utec and alky. I put down 456awhp with my stock maf.
--Josh
Old Nov 23, 2005 | 08:46 AM
SubiEvolved's Avatar
--Josh
Old Nov 23, 2005 | 10:19 AM
4ringturncoat's Avatar
I was running a solid mid 11's @ 122mph on a Dynoflash and the GT30r. The car drove great and made some nice power.
Old Nov 23, 2005 | 11:53 AM
ct9a gsr's Avatar
There's definitely no problem in using flash-based tuning on the stock ECU with a GT30R or even GT35R. Sure, you'll get significantly more power with a stand-alone... especially when using speed density, however, EcuTek will do the job fine. Just make sure your tuner knows what he is doing and scales the injectors correctly.
Old Nov 23, 2005 | 12:31 PM
aps's Avatar
aps
Ok well, ı'am really glad to that
Old Nov 23, 2005 | 01:15 PM
aps's Avatar
aps
But ı have a another question!!! What about the idle? Is ıt stalled after the 30r , because of not enough maf?
Old Nov 23, 2005 | 03:21 PM
Gruppe-S's Avatar
I would only recommend a standalone if you were planning to run different race gas map but ECUtek would be a better choice if your car is daily driven.
Thanks,
Tom
Old Nov 23, 2005 | 03:32 PM
nutrulz's Avatar
Works is doing similar with there time attack car and so does Garage HRS so it seems like a great option, I am going to be doing both.
DRAG
Jun 4, 2013 10:39 AM
kakarot305
Dec 16, 2010 11:56 AM
lukytry
10
Dec 6, 2005 12:23 PM
aps
Oct 27, 2005 03:39 PM
aps
Jun 11, 2005 03:46 PM
