Price for valve spring install
Old Nov 23, 2005 | 07:04 PM
nefblkevo's Avatar
I was planning on getting new valve springs and retainer when I put my cams in. What is a reasonable price to pay for the springs and retainer along with the cams?
Old Nov 24, 2005 | 12:47 AM
erioshi's Avatar
It depends on how they do it. Most shops will want to pull the head off the engine to replace the valve springs. While that is the right way, it's time consuming and the labor will be expensive. There are some short-cuts, but if done wrong they can also lead to problems down the road.
If you're planning on going with HKS cams, you are probably best off keeping the OE valve springs in place unless you're planning on eventually modding the engine into the "outragous" range. If that's the case, just leave the OE springs until it's time to pull the head for porting.
Old Nov 24, 2005 | 12:59 AM
Ultimate CC's Avatar
I would suggest leaving the stockers unless you plan on building the motor to rev out higher than 8k
Sheasta
Oct 21, 2015 03:28 PM
nesty2
Jun 25, 2015 08:54 PM
PHILLY EVO
19
Mar 7, 2009 05:41 PM
SooReal
10
Aug 25, 2008 03:54 AM
EVO8904
Nov 12, 2006 09:25 PM
