If its not one thing...its another
Old Nov 24, 2005 | 10:21 AM
Sap12687's Avatar
Unhappy If its not one thing...its another
tonight marks the first night my car has made any sort of tranny noise. Its also at least 25 degrees out too and this is the coldest ive ever driven the car in. The sound is an EXTREME whining and somtimes a 'clunking' depending on engine rpm AND throttle position. Under little acceleration it seems louder and in higher gears it also seems louder.
Could it be a sign of low transmission fluid? I did my own clutch about 2 months ago and im wondering if something went wrong. Im familiar with the typical transmission whine but this is not it.
Old Nov 24, 2005 | 10:30 AM
forum04pl's Avatar
from what your describing it sounds like a tcase, when a tcase blows it whines, and the higher the rpm the louder it gets. sorry for the bad news, but lets hope that its not that...
Old Nov 24, 2005 | 10:32 AM
rcheung's Avatar
I dont think thats normal. I've driven my evo last winter in below zero temperatures and snow. It sounds just like it would when it was warm out. The only difference is it takes a lot longer to warm up and may have a tad harder time starting up.
Old Nov 24, 2005 | 10:39 AM
Sap12687's Avatar
what are the other tell tale signs of a blown t-case?
Old Nov 24, 2005 | 11:11 AM
forum04pl's Avatar
clunking, expecially while turining, possible grinding or binding noises, but usually a whining
Old Nov 24, 2005 | 11:18 AM
Sap12687's Avatar
expecially while turining........ouch
Old Nov 24, 2005 | 03:09 PM
Sap12687's Avatar
just went for a ride and i noticed that it sounds like its coming from the rear of the car leading me to believe that its got something to do with the rear differential. Now i just remembered that i havent changedx the fluid in that little bad boy in ages....car has 13k and i bought it from Mitsu w/ 7k on it so unless they changed it, its been a while.
Old Nov 24, 2005 | 03:53 PM
akemi27's Avatar
me too!
didn't want to start another thread so sorry for whoring on over!
but yeah, this is the coldest it's been and now i've been hearing some humming sound, no grinds (not yet though)...at first it would start on the low end and would disappear but now, i hear it more regardless of the rpm's! why would the cold exacerbate this prob though? if i take it to the dealer would they fix it? (have a cbe, tp, mbc) i don't know about the dealers over here...
Old Nov 24, 2005 | 04:12 PM
smokedmustang's Avatar
Mine sounded like a Tornado siren! louder, when I got faster! If you put the clutch in, you could have pinched the "o" ring in there, and caused some of the fluid to leak out. If that is your issue, call Jon at TRE(team ripp) in Kalamazoo MI., He goes by the name GEARS on here. He will explain what happened. You can look at the thread I started, and there is a lot of people jumping in, to explain how theirs sounded. Either way, good luck!
Old Nov 24, 2005 | 04:27 PM
purecoda's Avatar
mine whir's everytime i downshift, though it isn't that loud. has ever since i got it, and rides fine. unless the noise is REALLY loud, or you can feel something while driving, i wouldn't worry about it.
Old Nov 24, 2005 | 06:46 PM
akemi27's Avatar
yeah this sounds exactly what mine sounds like...hoping it's not the tc - is it worth checking out? probably going to schaefer mitsu or circle mitsu over here
Old Nov 24, 2005 | 06:47 PM
Rez90's Avatar
that doesn't sound good
Old Nov 24, 2005 | 07:02 PM
My TC issue was only on acceleration, all gears, but more noticable in 4th/5th at 60-80 MPH, NEVER heard it on downshifting. so maybe its not the TC afterall!
Old Nov 24, 2005 | 07:05 PM
Evoryder's Avatar
bad transfer case = loud whining...sounds like metal on metal scraping
Old Nov 24, 2005 | 08:03 PM
Sap12687's Avatar
what are the consequences of a bad tc? performance/driveability wise
