boost leaks!
Old Dec 2, 2005 | 11:25 PM
nickracer9's Avatar
boost leaks!
pressurized my car and found about 3 bad leaks today. what affect do boost leaks have on power, tune and boost stability? turbo is a 35r. thanks.
Old Dec 3, 2005 | 07:21 AM
walkedu's Avatar
No boost = No power. What more do you want? Where were the leaks you found? Most likely they're at a flange or something you just need to bolt down tighter.
Old Dec 3, 2005 | 10:40 AM
nickracer9's Avatar
i was just curious what changes once i clear up this issue. tightening them down didn't do jack. it took a different style of clamp to actually hold w/o leaking. T-bolts suck, and everyone that uses them should check for leaks. they all leaked where the threaded portion was. I was running 20psi just fine, but with alot of leaks.
Old Dec 3, 2005 | 04:46 PM
nickracer9's Avatar
up
Old Dec 3, 2005 | 04:48 PM
justchil's Avatar
Get some tbolt clamps and or use superglue on the pipes.
Or you could search and see what everyone else is doing
Old Dec 3, 2005 | 05:47 PM
WHTEVO's Avatar
try and crank them down even tighter. not too tight though because you will start to cause the metal band to bend upward. you can try and put hairspray around the intercooler pipes, then put the coupler and clamp back on. check your couplers too, there may be a hole in it causing you to think it is from faulty clamps. good luck.
Old Dec 3, 2005 | 07:08 PM
kmcconn9's Avatar
hmm, I had this problem, and I got some t-bolt clamps and the problem was solved..
Where exactly are the leaks coming from??
Old Dec 3, 2005 | 07:14 PM
nickracer9's Avatar
it's the t-bolt clamp where the bolt is thats leaking. the more i tightened it the more it leaked. I got them all fixed by going back to standard hose clamps. it seems to have changed the tune a bit, seems the afr's are about .3-.5 points leaner. If you use t-bolts i would pressure check your system, you might be surprised what you find.
Old Dec 4, 2005 | 10:31 AM
wwxww's Avatar
how long should the air remain in the system , once presurized? i am hearing no loud leaks, now that i have plugged off the recirc and the valve vent tube, but i can hear air leaking from the engine and turbo area slowly. does the engine have to be at tdc?
Old Dec 4, 2005 | 12:17 PM
VTECH8TR's Avatar
This is an error in your part. Tbolt clamps when used correctly will hold anytihng you throw at them.
Old Dec 4, 2005 | 12:24 PM
nickracer9's Avatar
explain then! I know there are many diiferent styles of t-bolt clamps but these are 2.5 inch turbonetics clamps. I did mine at tdc.
Old Dec 4, 2005 | 12:27 PM
VTECH8TR's Avatar
Nothing to explain. You bolt them down and they seal. I run 30 psi daily with my tbolt clamps from NAPA. I am pretty sure turbonetics knows what they are doing if they made them. Please post up a pic of them for me to see them.
Looking at turbonetics part #'s here http://64.225.76.178/catalog/inst_accessories.html, maybe you needed the ones with part # 30275-238 instead of the 2.5.
Old Dec 4, 2005 | 12:32 PM
nickracer9's Avatar
yup there simple, but they leak. have you pressurized your system to see if they leak?
Old Dec 4, 2005 | 12:34 PM
nickracer9's Avatar
I also noticed that the jdm bov leaks at 25psi.
Old Dec 4, 2005 | 12:35 PM
VTECH8TR's Avatar
Yeah of course, i have used them on 10 evos soo far and my personal eclipse as well. I pressurize my car ALL the time, especially when i am making changes to it.
