Few important Questions regarding GT35R
Originally Posted by VTECH8TR
Kevin,
Just go with the 42R
". just kidding of course. I want to keep the A/C, and if the price for that is 7500, I would have to buy injectors/fuel-rail/top end/bottom end, etc.. and all the extra, to me, is not worth an extra 70-80 hp. Thats just me. Isn't 10 seconds fast enough? I want to road race it also.
Originally Posted by smokedmustang
Ludi, always great info! I want to be just like you when, and if I ever grow up!
Thanks as always for the input!
l8r)
I personally dont like the gt42R. I feel you can do as much with a heavily modified 40R and pickup about 1000rpm earlier spool. just my opinion!!
Originally Posted by WrX Kila
580whp with a gt3037R. You mean the gt3037R is bigger then a gt3076. Also whats the differnce between a -11 -12 -13 catridge for the 3076 I always hear about?
http://www.full-race.com/catalog/pro...products_id=66
we rate it to only 480whp however i feel we can break 600whp with the appropriate setup. Here is a comparison of a gt3037R vs gt35R, both .82 a/r turbine housings on a b series honda.
We have been testing with modified garrett R series turbos and have had excellent results. We will have our own versions of the GT turbos available for sale soon, the testing of our reworked 40R has been great, the 30Rs will be tested shortly. I prefer this turbo to the 3071 and the 3076
Correct me if Im wrong... the 3076 make more pwr right?Also why? Do you also recomend a gt series turbo with a big back housing? You mentioned that this was on a b series honda motor, will this turbo behave the same on the 4g63?
The GT3076 is what Garrett has for years (until this one) called the GT3037. This is a ball bearing center section with a gt30R turbine wheel and a 76mm exducer turbo. This is the turbo i am referring to, however we (Full-Race) modify the compressor and turbine housings approrpiately to improve their performance. I definately recommend gt turbos with the proper turbine size. Each turbo and engine setup will have an ideal turbine housing.
The 4G63 will behave VERY similarly to the B series, if it is properly modified, and vice versa, an improperly modified b series engine will make less power than a porperly modified evo motor.
That being said, Headwork, Camshafts, an excellent intake manifold (this is the hardest part as i havent seen many that can be considered properly designed), good turbo system, good intercooler, and a proper tune will all be necessary to make these power levels out of the turbo. The end result, however is fantastic. Great spool, huge broad powerband and instant throttle response with very little cylinder pressure.
Originally Posted by 11secEVO7
what is the most popular 35R
as far as options go...
eg trims,wheels etc...
4bolt,5bolt..??etc etc...
also which combo would make big power without much lag?
That being said, in the coming year, i expect the GT3567R to be more popular as it will exhibit identical spool characteristics with the same boost threshold, yet be capable of even more power. This turbo is very sensitive to proper turbine housing size and is very rare, but is amazing what can be done in the t3 frame
I would say the most popular 35R right now is the standard 35R, .82 a/r. This is an excellent mid-high power turbo with very good spool and throttle response characteristics. We have seen far more power out of this turbo than we ever expected, and it really is an incredibly well engineered turbo. Its easily available and fits a wide range of turbo kits. 4 bolt outlet is ideal as 5 bolt is more on center (Doesnt flow as well) and doesnt fit nearly as many applications.
the 35R with the .82 back...but I've bogged a few times on the line esp due to lag .so I ordered the smaller back end..I believe it is the 0.63
and well i'll still have the 0.82 so ill see how i like this for the while
