Cams: 272/272 with gears or no gears?????
Old Dec 7, 2005 | 12:20 PM
EVIL_EV0's Avatar
I asked a similar question to the Vishnu guys ...and this was about 264 cams.... See their response: https://www.evolutionm.net/forums/sh...d.php?t=165045
Old Dec 7, 2005 | 12:23 PM
Gruppe-S's Avatar
I think its well worth the extra money consider you already have the cams out for easy installation. Helix cam gears are on special for only $249 shipped and that will give you extra ~11 + whp. What more can you ask for?
Tom
Old Dec 7, 2005 | 12:52 PM
Ted B's Avatar
The purpose of adjustable cam gears has virtually nothing to do with idle quality.
The more duration one has to work with, the more the potential benefit to both power and torque from making adjustments to the cam timing. Someone with an HKS 280 set has far more to work with than someone with a 264 set.
And where that is concerned, it is not unusual to see an improvement along the lines of 15-20whp and 20+ ft/lbs in an already tuned EVO just from changing the cam timing.
Old Dec 7, 2005 | 12:57 PM
Ev0ikon's Avatar
You know what 's a waste! It's the d@mn sparking rock that I spent so much money on just so it would sit there and does NoTHING! I makes no addtional power to my car and all it does is sit there looking sparkly. Some poor bastid picked it out of a pile of dirt, polish it up and chargeed me a buttload of cash... and for what... It Makes ZERO power to my car..!!
phew..
or yeah.
now.. yeah.. cam gears are good if you like to tinker. It has potential to make power and doing so earlier in the powerband too.
Old Dec 7, 2005 | 01:06 PM
lexat20's Avatar
I still think for the $ you might as well spend a little more and get alky instead
Old Dec 7, 2005 | 01:22 PM
EVIL_EV0's Avatar
The cool thing about cam gears is you can sell them for almost what you paid for them. So even though you are looking at $250 for 15HP you're really only spending $50 because when it comes time to sell them you should be able to get $200 back.
The problem with cam gears is .... just setting them one way or another wont give you a specific gain. You need to have them tuned by someone that knows what they are doing.
Lets not forget alot of people seem to have problems with them coming loose. Not sure if that is installer error or just murphy's law.
Old Dec 7, 2005 | 02:27 PM
get faster's Avatar
+1. Gears are good ... if you use 'em. Do some research and move -3 or so.
Old Dec 7, 2005 | 02:38 PM
steelcityevo8's Avatar
runnin cam gears is optimum but not neaded with stock turbo, droppin them in with stock pulleys netted me 27whp with hks 272"s
Old Dec 7, 2005 | 03:41 PM
RazorLab's Avatar
Originally Posted by lexat20
If you want to spend $300 for a difference of about 5hp in a different rpm range go for it, but from my experience the only thing major gears will do is give you a smoother idle.
There is more to tuning and power than peak numbers my friend.
Old Dec 8, 2005 | 05:13 PM
hotrod2448's Avatar
phew..
or yeah.
Sparking rock? Do you mean Crack?
Old Dec 9, 2005 | 08:11 AM
timstrack's Avatar
Does anyone have the proper setting for the camgears running the HKS 272's along with all the other mods in my signature, I am running 91 octane. I have them set at 0 and after reading these threads I am seeing different opinions.
Any help is appreciated.
Old Dec 9, 2005 | 08:14 AM
Nez136's Avatar
From what i've seen, like posted earlier in the thread, its not worth getting gears unless you know what your doing. I have 272's w/no cam gears and i love them! perfect power band!
PS. I didn't buy gears b/c i couldn't afford it all at the time
Old Dec 9, 2005 | 08:17 AM
Ev0ikon's Avatar
I suggest -1 intake +4 exhaust.
Old Dec 9, 2005 | 09:24 AM
Ted B's Avatar
Perhaps the best use of cam gears with long duration cams is to set them such that midrange torque and spool characteristics are improved without hurting top end power and in some cases, actually improving top end power.
In your case, the weak link in the chain is the lousy 91 octane fuel, which isn't especially desirable where increasing low speed cylinder pressure is concerned. That issue makes me hesitate to make suggestions to you I might make otherwise. A methanol injection kit would remedy that though . . .
Old Dec 10, 2005 | 03:10 PM
timstrack's Avatar
I actually made the mistake of saying 91 octane, we have 93 octane here in AR. Do you run your camgears at -1 intake and +4 exhaust, and if so what were the hp gains. Were the hp gains measured on a dyno or the good ol' butt dyno.
