engine problem getting pissed!!!
my car hickups when i get on it
and it only happens in 4th
ill go through the gears winding each gear out
then 4th gear at 5,000 rpm it hickups
wtf!!!
i got the boost controller
hooked up to the wast gate
then to the turbo nipple
pushing 20 psi
wtf!!!
pushing 20 psi
Go to your local autozone/advance auto/pep boys and have them pull the code for free. If you want to see what your boost is doing that might help too. I know you're going pretty fast at 5k in 4th so it's hard to not watch the road but if you feel comfortable that may help diagnose the problem.
I highly suggest getting the code pulled though, more than likely that will answer all your questions. I take it the code appeared when the hiccup occured and not significantly before or after?
Originally Posted by MitsuEvoIIX
try hooking up the mbc to the bov??
Doesn't matter the boost level... its all about the Karman reading iirc the factory will cut boost around 1750hz ... if the air is cooler and more dense the boost cut level lowers.
might be a misfire...might be hittin boost cut. As Doug said its all about the Karman reading. Have you had some sort of reflash done? If no - send your ecu out and get the boost cut removed by a reputable flash tuner
