"turning up the boost"
Old Dec 10, 2005 | 11:38 AM
her0's Avatar
my AMS stage 3 was recently street tuned and the MBC just happened to be set to 18psi when tuned. Could I simply turn the boost up to 23psi or will I have to retune?
thanks in advance!
Old Dec 10, 2005 | 11:50 AM
Warrtalon's Avatar
A 5psi change in boost would typically require a retune. I don't see how the AFRs and timing could be optimized if you turn it up 5psi and were tuned at 18psi. What tuning device was used?
Old Dec 10, 2005 | 03:20 PM
her0's Avatar
tuned via AFC2
street tuned using an afc2
Old Dec 10, 2005 | 03:25 PM
SterlingEvo's Avatar
if you are just using the AFC, then that's super easy to "retune"...
Old Dec 10, 2005 | 03:30 PM
Warrtalon's Avatar
OH, then just go outside and retune it. No problem - that's why you have an S-AFC - so that you can retune whenever you change mods, boost, and/or octane.
Old Dec 10, 2005 | 05:54 PM
her0's Avatar
how?
damn. im very noobish when it comes to that. could you give me some more info? Am i adding more air/fuel?
thanks
Old Dec 10, 2005 | 07:40 PM
Warrtalon's Avatar
thanks
Oh, oops. You didn't tune it yourself from the beginning then, eh? The point of an S-AFC is to be able to tune it yourself, otherwise it's not very useful. Paying someone to tune an S-AFC for you is really icky, because you get more from a flash for the same price. I personally used an S-AFC for a while before getting a flash, and now I fine-tune on top of the flash with my S-AFC when using race gas. If you're not doing your own tuning, you should consider an alternative tuning device, preferably a flash of some sort.
I would not recommend going out and adding or removing fuel randomly. You need a wideband O2 to read the AFRs and a logging device to read timing. Both of those parameters need to be tuned together along with boost all at the same time.
Old Dec 10, 2005 | 07:51 PM
walkedu's Avatar
Are you saying that when i go to get my 1st flash in the next week or so, i can use my SAFC to adjust for race if i so choose? I was under the impression that i'd need to reflash or have a piggy back with more maps run race gas? Until i just read your post, i wasn't going to even buy an SAFC II and just stick with my DynoFlash. But now.... hmmmm??
Old Dec 10, 2005 | 08:14 PM
Warrtalon's Avatar
Nah, man, it's a perfect setup. A lot of us do this. You just get your custom flash for pump gas, then when you use race gas, you can turn up the boost and adjust the S-AFC to account for the higher octane. You still need to have monitoring devices to watch your AFRs and timing, but you can definitely make good gains this way. The S-AFC is a piggyback, and if you have the SAFC II, then it also has 2 maps in case you need to use them.
I only have the S-AFC I, which only has one map, but I just adjust the settings accordingly. I make MINOR SAFC adjustments on top of my base flash just to fine-tune according to the time of year, then more significant adjustments when on race gas. Start with the flash, then use the S-AFC on top of it for race gas if you want to go that route...
