Diagnose my Transfer Case
Old Dec 15, 2005 | 06:16 PM
Sap12687's Avatar
Arrow Diagnose my Transfer Case
What are the symptoms of a blown TCase?
Mine...
Extreme high-pitched whine at high rpm's in gears 2-5.
Sounds like metal-metal contact/grinding in the front end throught powerband.
When clutch is disengaged the noise continues almost a little louder.
History: Bought car w/ 7k miles and i swapped my clutch out at 13k. I havent even broken the clutch in yet. Car has been to the track once and other than that i have never gotten on it hard enough to cause a problem. I have never changed the rear diff. fluid and god knows if the dealer did. I put Synchromesh in the tranny and Redline 75w90 in the Tcase.
The strangest part of it all is i feel NO decrease in performance or driveability.
Anything and everything will help, i just want to know whats going on. Thank you.
Old Dec 15, 2005 | 06:25 PM
BaLListic_EVO's Avatar
it sounds like those old WW II bomb shelter siren's lol..... turn the radio wide open if u still hear it mmmm that would be the case
Old Dec 15, 2005 | 06:34 PM
dubbleugly01's Avatar
how many miles do you have on the Redline 75w90 in the T-case?
Old Dec 15, 2005 | 06:37 PM
Sap12687's Avatar
a little over 500
just to give you a sense of how loud it is......if i did turned the radio way up it would drown it out
Old Dec 15, 2005 | 06:40 PM
Originally Posted by Sap12687
a little over 500
it sounds like the t-case is bad, but the question is why?
Old Dec 15, 2005 | 06:48 PM
Sap12687's Avatar
whats the usual case? harsh driving or manufacturer defect?
Old Dec 15, 2005 | 06:59 PM
hard launches or wrong fluid. But hard launches usually breaks something, doesn't really make it whine. The t-case does not like GL-5 rated fluids, it performs best on the stock Mitsu Diaqueen fluid. Some swear by Redline, but it is GL-5 rated. Regardless, 500 miles on Red Line it way to quick to cause the problem. I'm at a loss. If you bought the car with 7k miles on it, I guess you don't know what the previous owner did, but the t-case fluid doesn't need to be changed that quickly, it would be an assumption to say he changed it anyway, and put the wrong fluid in it.
Old Dec 15, 2005 | 07:05 PM
34Turbo's Avatar
Its probably the tc. Mine went after I had changed the clutch at only 15K miles. I didn't do any hard launches or anything. I traded the sucker in instead of paying up the *** to fix it. They didn't even know the difference. Thats what might have happened in your case. Try to work it out with the dealer...
Old Dec 15, 2005 | 07:06 PM
Sap12687's Avatar
so what are my options now?
Old Dec 15, 2005 | 07:08 PM
Sap12687's Avatar
im under the assumption that the dealer is going to laugh in my face. Also, isnt it considered a wear item and not covered or am i off?
Old Dec 15, 2005 | 07:31 PM
forum04pl's Avatar
with your mods they will laugh at you, your best option is to send it to tre to get it built, its going to cost the same to get a stock one and the tre is warrentied
Old Dec 15, 2005 | 07:33 PM
no, the t-case is not considered a wear item and will be covered under the powertrain warranty. They probably would deny the warranty (assuming you fall in the time/mileage limit) if you have an aftermarket clutch or other parts on the car. Do you still have the stock clutch? I'm not suggesting that re-installing the stock clutch back in prior to taking it to the dealership would save you a couple $thousand........
Old Dec 15, 2005 | 07:57 PM
M3ss's Avatar
My drive drivetrain sounds kindda loud too but i think it's somewhat normal because it's awd!
Old Dec 16, 2005 | 05:44 PM
Turbojunkie's Avatar
that is exactly what is wrong. Mine did the exact same noises. new tc from the dealer is 3600.00. or you can get a remained one from tre if like waiting 100 years for their products.
Old Dec 16, 2005 | 06:04 PM
Sap12687's Avatar
im gonna try the dealer this weekend....this shoud be funny
