ix fuel cut at 17lbs help
Hopefully, that does it, LostSoul, but I've never reset my ECU after any mods, and I've never experienced anything crazy like this...
well leave it to me to have these problems thats just my luck i had a lemon before that had to be bought back and it was a scion tc believe it or not but yes ill try everything you throw at me sh** like this make me want to by a TL
No, you have to reset it at the battery.
Btw, Sean Ivey (IveyTuning) says there is a built-in boost cut that will most likely hit right after you install an exhaust, especially if untuned. You did say none of this happened until you installed the exhaust, right? See if the ECU reset works, but if not, then I think this is what's happening...it's specific to the IX ECU and doesn't happen to VIIIs.
yes right after the exhaust on the stock exhaust i could run whatever i wanted not now and i already think i know the answer to this but my car was alot faster with the stock exhaust isnt that crazy
one other thing i ment to mention along time ago which i think this is normal it SMOKES prettty bad but its black so i figure its just running rich but the thing that scares me is i cant get a reflash till end of jan now
yeah id be all over that i just cant scrape up the money who knows what christ mas will bring but do you think that in my case especially i notice a huge gain because ill also be able to run more boost i wonder how much
yes definatly that and i did a did a diagnostic on it and all it said it was cat insufficent so ive pretty much look from every angle thats why i flustered but im guess i try what warrtalon said
so before u go gettin a mail-in flash or safc2. reset ur ecu by either the negative ternimal or ecu fuses (since u have an 06'. the fuses should be the 2 small "20" fuses. 03-04 have a "15" and "20". make sure to look at the diagram on the fuse box so u pull the right fuse). dont pull the wires from the harness that is just more work and very unnecessary. im more than confindent that this will solve ur problem.
