ix fuel cut at 17lbs help
Originally Posted by slostjoe
ive searched for this thread no such luck i hit fuel cut at 17lbs i looked for leaks and checked with 2 diff guages what should i do stock boost ran more than that
well i apreciate all of your guys help with this ill go try that as soon as i leave work see what happens i just want it to run right
if that dont work. then disconnect the negative terminal when u get home. the first suggestion should work. but if the disconnecting the battery dont work i have no clue what to tell u.
hey what about an safcII i heard ams is doing one
Set the boost at 20-21psi on 93oct.
checked all gauge with two diff and i ONLY use 93oct and i never boost cold EVER well the reason warrtalon i asked about the afc is i have another friend with an evo who went back to stock has wideband and afc he tuned a gt35r wit jus that BRAVE
yes definatly that and i did a did a diagnostic on it and all it said it was cat insufficent so ive pretty much look from every angle thats why i flustered but im guess i try what warrtalon said
https://www.evolutionm.net/forums/sh...ht=anti-fouler
I personally have never thrown a code for the cat. with this installed.
