How do you prevent wheel hop
would possibly be worthwhile to look into rear diff carrier bushings. from what I can remember from a conversation with a friend, the rear diff bushings are soft and launching with the stock bushings could cause damage to the rear diff when it hops. if im incorrect with this let me know
Originally Posted by jbrown
wheel hop is the best way to break a trans.
motor mounts and a torque damper would help a lot with that. so would lower tire pressure and warmer track conditions.
You can also roll through the water box before you pull up to the line without doing a burnout, this will allow the tires to spin a little on the launch.
Slipping the clutch is probably the easiest way to CREATE wheel hop as it is likely to chatter when let out gradually, not to mention frying your clutch. At 5k rpm, you should be able to drop it all the way and just go.
Don
Today I did my first launch since the install of the Ingalls stiffy and Ksport coil overs. I still have bad wheel hop in the front. I am using the Advan Neova's in 245/40/17 and tire pressure around 38. It is cold outside too.
I used the two step, slipped the clutch, and all hell broke loose. I let off as quick as I could so I wouldn't damage anything. I don't know what else I can do to remedy this problem.
I am using an Exedy triple carbon clutch.
This guy does not need parts suggestions to avoid wheel hop. He either needs to raise his tire pressure, or launch with more of a feather as opposed to a dump.
dropping tire press will help with traction but i dunno ho wmuch it will help with stopping wheel hop...then again i don't even no how you can get wheel hop from the rear...considering you get front wheel hop because of the rotory motion of the crank causing the engine to kick back. which is why solid MM are helpful
Originally Posted by hotrod2448
I was going to say to drop the tire pressure. Are you sure about raising it? My buddy that used to work on a top fuel team told me to try dropping it to around 26 psi if I got wheel hop. I would think you would want the sidewall flex to soak up the hopping but, you are the drag expert.
I am not enough of a drag expert to explain wheel hop, but I do know what I've experienced. I don't get wheel hop from regular spinning when I lose traction. I get it with too much traction.
omniprobe
11
Apr 20, 2008 05:18 PM
Bosshog
Sep 19, 2006 08:44 PM
