Where to buy MAF (Mass air Flow sensor)
Old Dec 21, 2005 | 07:37 AM
clintonc's Avatar
hello i am trying to find a Mass air flow sensor or a after market one that is as good or better than the stock one or someone that is selling a working stock one. but with out the stock price. and it doesn't throw a check engine light if after market.
thank you.
Old Dec 21, 2005 | 08:17 AM
Ted B's Avatar
Do NOT attempt to fit an aftermarket MAF. Unless it has the same transfer function as Mitsu's MAF, it will NOT work.
If you don't want to buy a new one, perhaps someone who has converted to a standalone running speed density will sell you their used unit.
Old Dec 21, 2005 | 08:20 AM
Nez136's Avatar
thank you.
good luck, nothing out yet in the aftermarket world for different MAFs unless you can calibrate a GM or Cobra. Maybe you should look into the MAFTpro(deletes MAF)
Old Dec 21, 2005 | 08:25 AM
clintonc's Avatar
i guess hopefully someone will have a extra one they want to sell to me then
Old Dec 21, 2005 | 08:27 AM
3deep's Avatar
I have a stock one ill sell to you. I picked it up when i thought mine was bad,but had boost leak.$100.00 plus shipping.Pm me.
Old Dec 21, 2005 | 08:39 AM
Ev0ikon's Avatar
Or you can use ECUplus and GM's 3" MAF. or even 3.5" ones.
Old Dec 21, 2005 | 08:47 AM
clintonc's Avatar
ok after reading about how the stock MAF is restrictive over 350whp i will soon be over that so i have some options. sorry for the confussion but i have 0 MAF right now on a stock evo it was lost when i replaced my transmission and clutch and flyweel. so with that said
1 i can eather buy a stock MAF and be done untill i hit 350whp then cry
2 get a 85mm from gm but don't know or see a walk thru on how to do (i am not very machanicaly inclined) so all the help probably with pics would be nice
3 eleminate it completly and get this MAFTpro or will i run into problems later like the stock maf after 350whp and seeing how i would spend $400 on a stock MAF but it will be crap after 350whp and i hope to soon be over the 350whp mark
please help me i don't know what to do about this MAF problem i have
Old Dec 21, 2005 | 09:00 AM
Nez136's Avatar
the stock maf is not restictive over 350 whp.....that is a FALSE statement It is restrictive over a certain Hz, which i don't know how converts to CFM, but i know that the stock Maf should be good to about 2500 Hz (which is a lot of airflow). That amount is good for about 25 psi from any turbo (maybe not the gt35 and up). I would not worry about maxing out the MAF unless you are going to make 600 bhp+
Old Dec 21, 2005 | 09:03 AM
clintonc's Avatar
the stock maf is not restictive over 350 whp.....that is a FALSE statement It is restrictive over a certain cfm, which i don't know how converts to Hz, but i know that the stock Maf should be good to about 2500 Hz (which is a lot of airflow). That amount is good for about 25 psi from any turbo (maybe not the gt35 and up). I would not worry about maxing out the MAF unless you are going to make 600 bhp
ok thanks that is just what i read on the post talking about the MAFT pro thing
Old Dec 21, 2005 | 09:04 AM
Ted B's Avatar
The only MAF problem you have is the fact that you don't have one and you need one. Buy the one listed above.
As for the 'restrictive after 350hp' notion, that is complete B.S.
Old Dec 21, 2005 | 09:07 AM
Nez136's Avatar
The MAFTpro is a great unit, i almost sold my Utec for one, but i wanted to keep the stock MAF for now (until a Blow through setup comes along from Turbo XS). They will tell you what you want to hear so you buy there product.....
Old Dec 21, 2005 | 09:08 AM
Nez136's Avatar
Ted did you decide to install the turbo?
Old Dec 21, 2005 | 09:12 AM
clintonc's Avatar
sweet i found a forum that was talking about the stock MAF 350whp will restrict your car and now that 2 people have said that is b.s. ,but when i read that i started to ask myself why buy a stock one if i can get around this problem now and save some money seeing how i need a MAF or a way around the MAF now since my dealer bobby ford in lake jackson loses parts when they service your car but that is another story a very long story on how my dealer is crap.
Old Dec 21, 2005 | 09:27 AM
Ted B's Avatar
sweet i found a forum that was talking about the stock MAF 350whp will restrict your car and now that 2 people have said that is b.s. . .
It won't restrict you from having an 11 second car with stock turbo. Even if you were going to spend some $$ for an aftermarket ECU, you'd wouldn't be doing it primarily to 'lose the MAF'.
I'm still pondering it . . .
Old Dec 21, 2005 | 09:32 AM
clintonc's Avatar
well time for work and i think i got everything thanks to mmoranda and 3deep only part i am missing now is the
MAF harness thing it sits on
the stock intake box and filter
so maybe by new year i will have my evo back and running
viprez586
Jan 30, 2015 11:00 AM
cleanIX
Jun 4, 2013 08:49 AM
steelersgame
Sep 15, 2012 11:11 AM
twinturbogreg
15
Aug 24, 2010 01:46 PM
evodave
Feb 24, 2007 07:36 AM
