Destroked 2.4 block to 2.1 liter. Who has one?
I am really interested in this setup. I have searched the boards and I have not found anyone running this setup. I am curious to what some people with more experince than I have to say about it. I want to be able to rev up to 10k safely and have just a bit more displacement. I guess my questions would be:
Would a 20g turbo be able to produce power up to 10k rpm?
This is just a 4g64 block with a 4g63 crank and pistons?
Is slowboyracing the only vendor offering the 2.1 block?
Is slowboyracing good?
I can answer 1 question, there is no way the 20g will hold power to 10k. its only slightly bigger than stock and stock nods off at 6800 or so, 20 might, might pull to 8k but i think 7500 is more reasonable.
Marco Passante of Magnus Motorsports ran a destroked 2.4 in his car a year or so back. I'm pretty sure he's gone back to a long rod (156mm) 2.4L. This is not in an evo however.
jeff
jeff
I guess the biggest questions what the hell kind turbo would be best for me? I still want low spool but still be making power up to 10k.
for the most part, your going to get the same power band out of a turbo- if you can find a turbo that starts to spool at 3k and holds boost to 10k, wow... hence a sequential twin set up for more air... I guess its up to you- in the end, you get the same result- you just have to shift more for quarter- for road racing, you would have to keep the revs much higher all the time.
93 to 94 galant- you will have to get oil squirters installed... just do a google search on the motors (blocks) I can give you a link to a guy who imports jdm 2.4 blocks- I just have to find it......
Originally Posted by joeymia
I rather be be trapping 130 in 3rd gear. than have more displacement.
If you are really serious about using a 4g64, you need to call either Marco at Magnus or Robert at Road/Race.
Both of these guys are VERY familuar with the 4g64's can tell your anything you need to know.
