does our evo eats up oil???
Old Dec 22, 2005 | 10:02 AM
evo8forme's Avatar
I have stage 1+ on my car and everytime I redline or did a pull I can see smoke comming out through out redline. This happens only when i pull through out redline... if i'm driving normal... i dont see smoke.
Is this just because i'm a little rich? is it safe?
mods:
272/272
720cc
safc
walbro
10.5 hotside
tbe with test pipe
drop in filter HKS
MBC @ 21PSI
ACT CLUTCH
pLEASE ADVISE.... thanks
Old Dec 22, 2005 | 11:51 AM
evo8forme's Avatar
anybody??
Old Dec 22, 2005 | 11:52 AM
newimportowner's Avatar
If it is Black smoke it is Fuel and is quite normal. Blue Smoke is oil.
Old Dec 22, 2005 | 11:59 AM
Stinkapuss's Avatar
My 03 ate very little oil. My 05 drinks it up pretty quick.
Old Dec 22, 2005 | 12:08 PM
Vishnu_Evo8's Avatar
dude you have a test pipe.. do you know what that is? you have no cat.. look up any dyno pull of a catless car... every evo especially catless shoots out black smoke.
Old Dec 22, 2005 | 12:14 PM
Fa$[- a$ $hi[-'s Avatar
mine doesn't use a drop of oil, as it shouldn't.
Old Dec 22, 2005 | 12:19 PM
C6C6CH3vo's Avatar
Your car likely is fine
Old Dec 22, 2005 | 12:23 PM
keevo54's Avatar
between oil changes does the oil level drop. an easy way to tell if you are burning oil
Old Dec 22, 2005 | 12:24 PM
SuperHatch's Avatar
All your base are belong to us...
Old Dec 22, 2005 | 02:01 PM
evo8forme's Avatar
if your engine is eating up oil is that bad? I do have to add oil between oil changes at times... because after a few good run the oil level seems a bit low.
Old Dec 22, 2005 | 02:04 PM
Ryu123's Avatar
Mine doesn't eat up oil. I haven't had to add any between oil changes.
