overheating problem..or so the gauge says.Please read.
Old Dec 26, 2005 | 04:10 PM
rraulston's Avatar
i would verify the function of the thermostat. Pan of boiling water trick. Hold it with some needlenose pliers and dip it in and watch it open, or not.......
Old Dec 26, 2005 | 04:49 PM
11secEVO7's Avatar
well at first i thought it was the thermostat so i had it changed.
so i assume that's out of the question now
Old Dec 26, 2005 | 04:58 PM
electr0's Avatar
Mitsu had a recall on the fan controllers being faulty. I had to go in for it. I would check to see if you are one of the people that are succuming to it. They had to replace the fan controller.
Old Dec 26, 2005 | 05:48 PM
11secEVO7's Avatar
wel my car is a 2001 E7..
i dont think i have this fault.
but regardless i set up the fan to work as soon as ignition is turned on. It doesnt go through the controller anymore.
so the fan is constantly on as soon as ignition is on.
Old Aug 27, 2006 | 08:44 AM
roberttonge's Avatar
I have the same type of problem on my JDM EVO VII, reply to me if you get this problem fixed robbytonge@hotmail.com, i live in the Caribbean too Dominica.
Old Aug 9, 2009 | 01:41 PM
BBYBruno's Avatar
Was the overheating problem solved? I have this problem now also.
Old Sep 10, 2009 | 10:28 AM
BBYBruno's Avatar
Well I fixed my overheating issue. I replaced my thermostat with an oem mitsu thermostat, replaced the radiator cap, used radiator clean and flush solution in my stock radiator, since then it stoped overheating.
Old Sep 10, 2009 | 11:39 AM
cij911's Avatar
Based upon the fact that the problem happened after you installed a new exhaust manifold I am guessing the problem is either : (1) new manifold is too close to radiator (doubt it) or (2) when you drained and refilled your radiator you did not bleed the system properly and have an air bubble in the system....Pressurize and bleed the coolant (there is a how to in the how to section...) and see if that solves your problem.
SilentCool
Lancer Troubleshooting
Sep 22, 2015 05:57 AM
SmurfZilla
34
Jul 16, 2013 06:48 AM
crisdiarata
Jun 1, 2012 10:40 PM
hatakashi
20
Oct 22, 2011 09:30 AM
