Forge MBC
Old Dec 29, 2005 | 08:10 PM
steevo's Avatar
Ok...considering the soft spring comes with it....thats what i must have. I dont want to turn the boost up for gears 1 and 2, and then have other gears boost too high...thats what i'm afraid of. I am stock right now except for cams (dont know which one's yet), so will I be OK turning boost up to tune 1st and 2nd gear??
Old Dec 29, 2005 | 08:48 PM
Warrtalon's Avatar
You always boost less in lower gears, because there is less load. This is just a basic principle.
Old Dec 29, 2005 | 08:59 PM
steevo's Avatar
Thanks for that answer...i needed that. Im still learning alot of the basics. I need to contact Forge for the stiffer spring for bigger boost in the future, or get a new mbc.
Old Dec 29, 2005 | 09:02 PM
Warrtalon's Avatar
No, it's the best MBC. Just get the stiff spring if you want to go over 22psi, or get the Forge Wastegate Actuator that changes the base wastegate pressure. Since they come by default with the red spring (19-24psi), that means you will never be lower than 19psi. Then, with the soft spring, you just slightly adjust it up from 19 to 21...or as high as 29psi max.
nikush
Apr 14, 2016 05:53 AM
asdfasdf128
Oct 24, 2010 06:14 AM
mscorei
Sep 10, 2007 09:20 AM
PEARLEVOIXMR
30
May 16, 2007 06:24 PM
jxn evo 8
15
Apr 16, 2006 07:34 AM
