gt35r with ported shroud...?
Old Dec 29, 2005 | 01:38 PM
smg944's Avatar
i have been looking at the gt35r with the drilled ported shroud. i was wondering whos running it, and how the boost responce is. also i heard it makes that nice loud turbo whistle like the hks t51r. also i heard there are some drawbacks with the ported shroud with responce and power, i was wondering how much of a loss it is. thanks in advance.
Old Dec 29, 2005 | 03:24 PM
evolved4g63's Avatar
Um, dont know about the whistle sound. Guess you mean the sound of air going into the compressor? Yes, i for sure hear air flowing with the ported s cover. Alot more than my old 50trim with the e comp. cover. As of yet i dont know what any of these drawbacks are? If any. The reason for using the ported cover is the surge problems with this large a turbo and the regular 3in. inlet e cover. There is still surging problems with the ported shroud but not nearly as bad. The only time i see surge is in 5th gear on the highway.
Old Dec 29, 2005 | 06:04 PM
smg944's Avatar
evoleced4g63, is your turbo drill style ported or does it have the "double intake" style ported shroud? btw, thanks for the responce. i have an rx6 turbo kit right now, and its spools really quick. it doenst have a ported shroud on it though. from what i heard with the ported shroud you get no/less surge, and the turbo whisltes loud, but you lose some hp on high boost and get slightly slower responce. heres a link to what a t51r sounds like, they also have a ported shroud. this rx7 is running 18psi.
C:\Documents and Settings\STEVE\Desktop\StillwayFD3S.htm
Old Dec 29, 2005 | 06:24 PM
jj_008's Avatar
What your saying about ported shrouds is correct, except the whistling sound. At least mine doesn't whistle. Ported shrouds are nice on EVO's due to the high boost levels and big compressor wheels. So what is lost in peak performance is gained back w/ better driveability.
What model RX6 do you have? Do you have surge issues w/ it?
Old Dec 29, 2005 | 07:32 PM
Mine is the drill style, PTE. But i'm with jj, i have no clue as to what you are saying about whistling noises? There is less surge with my current setup than with the plain "e" comp. cover. With teh e cover on a 35r you would most likely see surging in 4 and 5th gears, staring a pull in the low rpms. Maybe even third depending on conditions. Now i only see some in 5th.
importdps
11
Jan 30, 2008 10:43 AM
discopotato03
Nov 26, 2006 01:13 PM
ItalianEvo
Feb 15, 2006 03:20 AM
TomsEVO
Jan 4, 2006 01:57 PM
TrinaBabe
Apr 3, 2005 05:48 PM
