Clutch pedal adjustment.....when?
Old Dec 29, 2005 | 08:10 PM
03SilvaEvo's Avatar
I read about adjusting the clutch pedal and its seems pretty easy to do. How do I know when its time to adjust my pedal? I still have stock clutch with 16,500 miles.
Old Dec 29, 2005 | 08:13 PM
evo_rc's Avatar
well is your clutch engaging properly? if your not having any problems I would leave it alone....
Old Dec 29, 2005 | 08:20 PM
03SilvaEvo's Avatar
Yeah it does. Sometimes when I shift into 2nd or 3rd gear the stick don't want to go all the way and I end up missing the shift. Does that mean a clutch pedal adjustment is needed?
Old Dec 29, 2005 | 08:25 PM
Matz's Avatar
Or maybe a synchro issue? Didn't our 03s have a recall of some kind for the 2nd and 5th gear synchros?
Old Dec 29, 2005 | 08:28 PM
evo_rc's Avatar
+1 ^ are you getting any grinds at all too?
Old Dec 29, 2005 | 09:00 PM
ACTman's Avatar
Why not just adjust the pedal a bit and find out if it improves shifting? By raising the engagment point you are reducing the free play and increasing the travel of the release bearing to disengage the clutch earlier and farther. Once adjusted, it shouldn't need it again. The hydraulics are self-adjusting for wear.
Old Dec 29, 2005 | 09:02 PM
SnakeEater's Avatar
Question
Was there a recall?
Old Dec 29, 2005 | 09:19 PM
NIevo's Avatar
Id take it to the dealer and see what they have to say. I got my first and fourth gear syncro's replaced even with my mods. You can try adjusting the clutch pedal but if it is a syncro going out it would be better to have it replaced under warranty.
Old Dec 29, 2005 | 10:06 PM
ACTman's Avatar
If it's the syncro going, adjustment won't help at all. It seems like all that most dealers know how to do is replace parts, not diagnose the problem or the cause so why rely on them? Why not adjust the clutch and find out for yourself. It might cost you 10 minutes of your time.
Old Dec 29, 2005 | 11:39 PM
evo_rc's Avatar
Originally Posted by SnakeEater
Was there a recall?
are you joking? if not then yes 03 evos have this problem and mitsu. is aware of it. I got mine replace under 10 k miles.
Old Dec 29, 2005 | 11:43 PM
Deepseadiver's Avatar
^ I don't think it was a recall! Just a TSB
Old Dec 29, 2005 | 11:55 PM
evo_rc's Avatar
well your right, my point was some 03 evos have synchro problems......
