EVO IX MR Flutter?
... wow, frustrated.
i am hearing everything from... "this is normal...." to " this is very bad (hard) on the turbo and it should not be doing this.
not sure if i should be persuing this further or not...
any tuners care to weigh in on this?
It is normal. The MR is a strong BOV. There are some cars that dont even have a BOV and their turbos last forever. As warrtalon stated it happens, even on a stock car you just can hear it becuase of the stock intake and box. Shift faster, let out of the throttle quicker, or put the stock intake back on and you wont hear it. Most aftermarket BOV's will make the flutter worse at part throttle so people have some they like, search. Ours cars build alot of boost quick and so low in the RPM's it is very hard to get good release at low and high loads. Flutter at low RPM's low load and hold great boost up top. No flutter and leaky at high boost. Its hard to find a medium.
agree on normal
I have a bone stock IX MR and it's exactly as Warrtalon states ... if you let off the gas lightly and not quickly, there is some surging ... I quickly learned not to do this
You can go partial throttle, but when you lift, lift quickly and completely to allow the BOV to fully purge in a single breath ... makes things much smoother.
Your car, if all stock, should have absolutely no surging or stuttering. Even an intake and exhaust should not cause it. I have had this issue on my car, tried 4 different BOV's (stock, Greddy, Forge, Tial) and the only one that did not stutter at all was the stock BOV. Never ever stuttered.
EVOlutionary
EVOlutionary
EVOlutionary
EVOlutionary
By "if all stock" I meant if the BOV was stock also. I find it hard to believe Mitsu would sell a car that has compressor surge straight from the factory. I could be wrong, though. If I am wrong, he could try the plastic '03-'04 BOV if he really want to get rid of it. Maybe that will help. Good luck! I know it is a pain in the a$$.
EVOlutionary
EVOlutionary
Hey, man
I have a IX and had the same problem as you do. I have an intake w/ the injen hard pipe kit. I switched the BOV to the proper OEM position and the flutter was gone. It is perfectly..and I mean perfectly smooth transition at part throttle and low to 0 boost to vacuum.
PM me if you need more info.
Originally Posted by Mr. MR
One solution could be an adjustable BOV like the Forge RS. It has a knob to turn spring pressure up or down which controls when the boost is released (if I am explaining correctly?). So for you, you would set it at it sofest setting and adjust up till you start to hear/feel the flutter. I just set mine and it has almost eliminated the fluttering, but turbos don't like partial throttle I am noticing. BTW, it is louder than your JDM MR BOV. Another benefit is that it holds more boost pressure than the JDM or stock BOV.
I sell them at a very dicsounted rate - PM for details
When the car is 100% stock you will not notice this at all
However - when you modify the exhuast - e.g. modified down pipe and free up back pressure then the tendancy increases to flutter on partial throttle
This is why a fully adjustable bov like the Forge RS will allow you to dial in the BOV to suit your own individual driving style and prefered "feel"
Er, yes, I know we are talking about the stock BOV. I was telling you that what you experience with the weak, crappy, plastic BOV is nothing like the JDM MR DV . . . the compressor surge is caused by improper driving: part-throttle, slow lifting in high gear after buildiing low boost . . .
As for compressor surge being caused by improper driving - you can feel free to change your driving style to work around a problem your car is having. I personally would rather fix the problem than just tip-toe around it. Having to drive my car like a light switch , on and off, is fine for drag racing, but unacceptable for any other kind of driving. It is absolutely necessary to be able to drive at part throttle and be able to lift off to slow down smoothly for a sweeping corner while not upsetting the balance of the car.
EVOlutionary
Originally Posted by taenaive
yeah, BOV flutter it is. you hear it when you have the intake. if you have the stock intake box, you just don't hear but it is there. It is the bit of down side for owning turbo charged cars. you don't want to stay in partial throttle with the turbo. you eithter go fast or go slow. don't do medium.
HPEVOX
27
Apr 14, 2010 06:23 PM
