what fluid to use in 05 x-fer case?
Originally Posted by 4g63girl
can i use any gear oil such as redline shock proof ? or is there something it has to use due to the acd?
thanks
Emery
thanks
Emery
It's about $50, here is the link http://www.evomoto.com/product_info....roducts_id=220 and there is a how to section also http://www.evomoto.com/tech_info.php...d4c79813f1615d
Trust me stick with the Mitsubishi Diaqueen LSD gear oil, TRE tells all there customers to stick with this fluid because it has proven to be the best in our transfer case. I would listen to them especially since they have been working on transmission and transfer case for a long time.
Mitsubishi Diaqueen LSD gear oil hands down. I believe Lancershop sells it for just under 50 dollars for a gallon of it. A gallon of this stuff will last you numerous fluid changes.
